Old 03-06-2005, 06:56 PM
ExecutiveNet's Avatar
Send a message via AIM to ExecutiveNet
Default Offtopic: HT1000 Programing Cable
there is a schematic for a programing cable on batlabs, and i am wondering if this is for a ribless cable for the HT1000, i can build it, but i want to know if i need the Rib box for the schematic,
http://www.batlabs.com/images/mt2kpin.gif
also,
do i just connect the open wire to the radio, and plug the 25 pin into my computer?
any help on how to build it would be great
Old 03-06-2005, 07:38 PM
Send a message via AIM to jwood
Yes you need a RIB, the only Portable that does not use the RIB is the XTS 5000 and 2500 series radios.. You can get a HT-1000 Programing cable on ebay...
Old 03-06-2005, 07:41 PM
arn't there ribless cables for the HT1000?
Old 03-06-2005, 08:13 PM
hulka's Avatar
Send a message via ICQ to hulka Send a message via AIM to hulka Send a message via Yahoo to hulka
Not that I have seen. The "Pro" series radios have "ribless cables too. HT-750-1250-1550.
Old 03-06-2005, 10:29 PM
jhooten's Avatar
There are three listed on ebay. Can't say if they really work, but they are listed as ribless cables for jedi type radios.
Old 03-06-2005, 10:42 PM
FuelForFire's Avatar
Yes, there are "ribless" cables for the HT1000 and other jedi protables but all they are is a cable with a built in rib. The cable still needs it own power source to operate. None of thse cables are from the factory.
In my opinion, such cables are a huge waste. You are still paying for a rib but you cannot use it with any other radios and it must be powered by a 9v battery instead of a wallwart and a battery is never to be trusted when programming your $1000 radio.
Old 03-07-2005, 10:49 AM
jhooten's Avatar
You should use a laptop with a good battery and plugged in to the wall outlet and a rib pluged in with a good battery inplace. If you ever had the power go out in the middle of an upload you would understand why.
Old 03-07-2005, 10:58 AM
Send a message via ICQ to Thornhill20 Send a message via Yahoo to Thornhill20
Not necessarily. A friend of mine bought a ribless cable for a Jedi (HT1000) series that requires no external power. It uses very low current devices and is able to use the 5 volts present on one of the serial port pins.
Failing that, you could very easily modify the power to take 5 volts off of a USB port or a PS2 keyboard/mouse port...they all provide a very stable 5 volts with more than enough current.
-M
Old 03-10-2005, 02:42 AM
-M
[/quote]
The standard RIB uses 9 volts to program. If you can get by with 5 v, hey, thats fine, but there has to be a reason for using 9volts. Maybe its just so you can more easily use a battery. I dont know.
But the bottom line is: unless you want to run with risk of creating an expensive door stop I would spend the money and get a facyory rib and a factory cable and use a reliable power source (such as the wall...).
Whats out there as far as aftermarket programming equipment is simply not as reliable.
