Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 12-06-2008, 2:24 PM
Question HT1250 Radio Locked Issue
I have had this VHF 1250 for nearly 4 years and using it as my personal Radio during Patrol. With me in Law Enforcement I wanted the radio to be locked when turned on.. It would ask ENTER PASSWORD. I would enter my assigned password and then I would be locked in. I had it Password protected at powerup that way no one would find it if lost and transmit on my Departments freqs.
Anyway.. I actually left this radio for about an hour at a friends.. And apparently he took it and tried to figure out the password. According to Motorola it Locked the radio.. due to to many incorrect tries of the password, it locked it..
now the radio only says RADIO LOCKED and cannot get it to allow me to log in or anything..
I read the radio with my laptop with my RIB and software.. and tried to uncheck my password login and it will not write to radio nor allow me to unselect the disable password login at startup.
I have never seen this on this radio in the 4 years of me owning this.. My friend isnt into radio he has no clue about this stuff so I know he didnt nor would he ever try to have it programmed and with only an hour of the radio there wouldnt even be much time for issues to have happened..
I have tried pushing many buttons then turning power on to allow me to enter my password.. I have held nearly every combination of buttons I could think of trying to get into a menu.. the only thing it will allow me to do it put it in CLONE mode.. thats it.. otherwise screen says RADIO LOCKED..
also it does have a full DTMF pad also..
Thanks for all the help..
Hope someone has some info or help..
Old 12-06-2008, 7:50 PM
N2MWE's Avatar
If nobody knows here, go to www.batlabs.com
I've done my bid for king and country
Old 12-06-2008, 8:47 PM
w0web's Avatar
Default Ht-1250
I would try and call the big /\/\ @ (800) 814-0601 and ask for post sells support, I do have an account and have found them to be very helpful with radio support.
they asked for a copy of the codeplug to be sent to them and they sent it back corrected and all I needed to do was write it back to the radio ( all while I was on the phone with them)
George H. (wweb)
scanner4@gmail.com
Old 12-06-2008, 9:19 PM
gatekeep's Avatar
Leave the radio turned on for 15 minutes. It should unlock and allow you to enter your password. If it does not unlock, then you have to, have the depot repair the radio.
- Bryan, WQDK979
"So the best solution is to paint them to blue color and throw them to the sea?" in reference to MTS2000 F01/93.
Old 12-06-2008, 11:38 PM
THanks for the replies.. I had the radio off for 15 minutes.. Same thing.. Says Radio Locked.. I will take it back to Moto shop see what they say this time.
Old 02-22-2011, 11:30 AM
Astrak's Avatar
I think he was saying to leave it ON for 15 minutes.
WWW.APSN.US
Old 02-22-2011, 3:13 PM
XTS3000's Avatar
There is a small coin cell battery in these radios. If it doens't come back to life after 15 minutes, replace the internal coin cell battery. With dead coin cell, the radios internal clock stops.
Old 02-24-2011, 8:31 PM
joetnymedic's Avatar
did you ever fix your radio or did the shop have to do it?
Uniden 396XT/T, Pro 163, BC346XT, BC700A, Pro 528. PRO 2018, PRO 136, Pro-197, Motorola CDM1550' Minitor 3,4&5's. Baofeng UV-5RA, UV-82Lx2 ,CS700,BCD436HP 996P2, KG-UV9D, ADS-B, XTS3000x3
Tags
1250 issue, ht1250, radio locked
