Old 07-05-2009, 07:47 PM
Default Motorola CDM
How do you hook the programming cable up to program a CDM remote mount??? Do you hook up thru mic port on control head or straight to radio its self... If someone could give me a run down on this it would be nice... Thanks Jeff
Old 07-05-2009, 08:24 PM
Send a message via AIM to fineshot1
The mic jack on the head is used - same as if the head were attached to the chasis.
fineshot1
NJ USA
Old 07-05-2009, 10:24 PM
That is absolutely INCORRECT and will brick your radio. If you don't know the answer keep your mouth shut. You need to use the rear accessory connector which is the safest way to program the CDM in the first place.
Old 07-06-2009, 05:52 AM
I am speaking from experience and know quite well what I am talking about.
I have this setup in my shop, a test radio that was once in a mobile unit.
Yes - you can program the CDM series from the accessory connector but it is
not necessary unless you have specific reasons or needs to do so.
I don't know where you get your information from but it's time to re-educate yourself
on this one.
PS - I have never bricked a motorola cdm radio using either method and have programed
many of these.
fineshot1
NJ USA
Old 07-06-2009, 07:35 AM
N2DLX's Avatar
Send a message via AIM to N2DLX
I concur, program via the mic jack on the radio's head. Don't try to program via the jack for the remote head unit, THAT'S the unsafe part. I've been programming CDM's for a long time and never once had an issue or bricked one. Make sure your cable doesn't pop out while programming and you should be in good shape!
Old 07-06-2009, 10:01 AM
SD70MAC's Avatar
Default Cdm
I also would agree that you should program a remote mount CDM from the rear 20pin port. This would be safest way because the CDM some type of issue with the remote set up. Some program ok from the mic port and some don't but you will only know when its too late and you have an eeprom cs error. I have fixed about 4-5 for people that got the eeprom error. NEVER USE A USB cable of any kind for the HT/CDM you will be sorry at some point.
SD70MAC OUT
XTS5000 VHF FPP,HT1550XLS VHF FPP,HT1250 VHF,HT1250LS+ UHF,HT750 35-50, 2 CDM1550LS+ VHF 160ch,1 CDM1550LS+ UHF 160ch,GM300 VHF,MAXTRAC VHF 32ch,MAXTRAC low 42-50 32ch,MCX100 RAILROAD
Old 07-06-2009, 11:34 AM
OK - perhaps I missed something - but I am looking at section 4(Radio Programming and Tuning Procedures) in the CDM Series Basic Service Manual 6881091C62-C and it does not mention that
programming via to 20 pin accessory connector "is a must" in the remote head configuration.
Perhaps someone can tell me which documentation this is pointed out in, or is this some
un-documented moto thing?
fineshot1
NJ USA
Old 07-06-2009, 12:32 PM
fireandems13669's Avatar
Send a message via AIM to fireandems13669 Send a message via MSN to fireandems13669 Send a message via Yahoo to fireandems13669
Program them everyday through the mic jack on the cdm remote heads no issues
KC2VHB
Old 07-06-2009, 12:33 PM
iamhere300's Avatar
As a MSS, we have seen LOTS of CDM radios, in remote mounts. Never have we bricked one of them by using the microphone jack on the control head.
Never.
We also use USB converters for the cable also - no problems.
Old 07-06-2009, 12:44 PM
thanks 13669 & 300 - i thought that was the case but i just wanted confirmation that i was not missing something.
fineshot1
NJ USA
Old 07-06-2009, 01:27 PM
I just programmed 2 right now through the mic jack on a remote head.
Somebody got a little jumpy up there.
Old 07-06-2009, 02:23 PM
Send a message via AIM to tdeater Send a message via Yahoo to tdeater
Smile Maybe some truth both ways...
I have a few in my fleet with remote heads, and have never had issues programming them from the mic port. I did hear from another service provider that if you purchase some of the aftermarket remote head kits, they have seen them have problems programming trough the mic port. According to them, if you use the Motorola kits, there are no problems. So, in a way, there may be some truth to both sides of this. Again, this is what was told to me. I use the Motorola kits on my radios without any problems, other than the inadvertent user installed the cable in the way of the sliding seat rail cut.
Old 07-06-2009, 10:21 PM
I use Motorola parts and program radios almost every day through the mic jack on the remote head and have no problems. There is nothing wrong with going this route. NOTHING.
~Jay~
K3JLT
WQBY457 (GMRS)
www.lima911.com
Old 07-07-2009, 04:34 PM
You may be able to break the speed limit 100 times and not get a ticket. Doesn't mean you have a fool proof system. With the new CPS being able to correct the EEPRM Error, this is less of an issue as you are less likely to send your new paperweight to the depot. With a remote mount I was trained by Moto to never program through the mic jack.
Old 07-08-2009, 08:42 AM
How long ago was this training? Perhaps you can locate your training material that points this out?
I can not locate online or otherwise any doc that points this out.
BTW - your response of "If you don't know the answer keep your mouth shut." was totally un-called for!
fineshot1
NJ USA
Old 07-08-2009, 03:01 PM
Just my two cents, maybe they were talking about the dual head kit. You are never supposed to program the radio with the dual head kit. You are supposed to disconnect one of the heads from the interface box, and connect the heads control cable to the radio chassis, then program.
In a remote mount, the jack on the front of the radio chassis, and the one on the rear of the head, are control cable jacks, not mic jacks, and should never be used to try to program. The mic jack and the rear accessory jack are both acceptable programming points. Like many have stated, I too have programmed hundreds of radios over the years through the mic jack and have never bricked any.
Old 07-09-2009, 03:32 PM
Default let me make this straight...
"NOTHING" absolutely "NOTHING" will happen IF you use the correct motorola RIB, CABLE, CPS, POWER SUPPLY.
i have experience from about.... let me think.... 8-900 radio's
CDM's HT's MT's CP' GP's GM's GR's EX's & more!
Old 07-28-2009, 10:55 PM
Default 20 pin RIB part number???
My organization uses plain faced CDM750's for Repeater and Link TX/RX. So I don't have a mic plug. I am looking for the programming kit for the 20 pin connector. Do any of you know the part number for that item? I need everything. Software, Cable(s), RIB.
Old 07-29-2009, 08:45 AM
AARKN4083 - 20 pin cable
need rib box also
Old 07-29-2009, 08:51 AM
Would the RIB be a FKN8113? It's funny how you can buy the cable for the mic jack all over the internet but when I punch the 20 pin cable part number into Google lots of info comes up but no place to buy one...
Is there any suggestions on where I might be able to find all three items I need?
Similar Threads
motorola cdm 750 as intercom brin831 Motorola Forum 0 06-15-2009 03:32 PM
FS: Motorola CDM 1250 1550 remote head Asmitty0010 Old Classifieds Archives 1 05-04-2009 12:16 AM
FS: Motorola CDM series remote head kit Griggs Old Classifieds Archives 3 09-10-2008 07:54 AM
Motorola Announces Aid to Hurricane Katrina Relief Efforts mmartinfan General Scanning Forum 0 09-06-2005 09:35 PM
