  #81 (permalink)
Old 02-02-2011, 9:31 PM
I cant seem to make it work...
RadioShack® USB-PC Interface Cable for GRE Scanner - RadioShack.com
Will this cable work? I can not find it, but do you have to do any mods to that cable? And is that a 1/8" stereo jack?
Thanks,
Bigdoggg
  #82 (permalink)
Old 03-12-2011, 5:26 PM
Default Thank you!
This worked flawlessly - what a fantastic idea. I really appreciate you posting this!!!
  #83 (permalink)
Old 03-18-2011, 5:22 PM
JJones27320's Avatar
I just made mine out of the RS scanner plug and downloaded the Minitor IV Dos version of the software, but I was wondering if anyone has a copy of the windows based minitor IV software they could email me.
J L JONES - KC4WBL
  #84 (permalink)
Old 03-31-2011, 12:49 PM
I just built This. I used all of the items listed and when I go to program the scanner programmer light blinks red once and it says failed for scanning the codeplug.
  #85 (permalink)
Old 04-01-2011, 6:41 PM
theman21
sounds like you have the wrong com port selected in the program
  #86 (permalink)
Old 04-01-2011, 6:46 PM
jjones email me tjacks3441@gmail.com
  #87 (permalink)
Old 04-04-2011, 2:42 PM
I really need to get one of these, but I'm not about to spend 300 on the actual cradle. Would anyone be willing to make a simple one for me and I'll send you some money via PayPal? It would be a huge help as I'm not great with soldering and all.
  #88 (permalink)
Old 04-06-2011, 1:52 PM
rogo43
  #89 (permalink)
Old 04-06-2011, 3:32 PM
SteveC0625's Avatar
Uh, the Motorola programming cradle kit list price is $224. There is also an after market kit available for $135 from minitorprogramming.com
Dunno where you got the $300 figure from, but it's a bit high.
  #90 (permalink)
Old 04-15-2011, 11:47 AM
Has anyone tried to use an 8 pin Kenwood programming cable for this? I have a USB 8 pin RJ-45 kenwood programming cable (KPG-46 I believe). I am not quite sure what the pinout is on it. Anyone have any ideas on the pinout of that cable, and if this would be possible?
  #91 (permalink)
Old 04-16-2011, 10:06 AM
jaymez99
look at the first page it looks like somebody may have used what you are talking about.
  #92 (permalink)
Old 04-16-2011, 10:11 AM
Originally Posted by tjacks34 View Post
jaymez99
they did, but with a 6-pin RJ-11 setup, i need it for 8-pin and RJ45. I am going to try to do some guessing tonight.
  #93 (permalink)
Old 04-16-2011, 10:16 AM
the tx and rx have to have around 3.5 volts thats the only thing
  #94 (permalink)
Old 04-19-2011, 10:00 AM
Default Can't get it to program
hello,
I am trying to get this to work. I have it hooked to my old desktop computer with a serial port. A chief of a local fire department has the motorola purchased programming stand. I have hooked that to my computer and successfully programmed my pager.
I am attempting to do this with the acroname rs232 to ttl converter shown below
Serial Interface Connector
I have 3 wires hooked into it. tx, rx, and ground. I touched those wires to the appropriate pin holes on my pager. My pager IS in programming mode. I cannot get it to communicate. I have tried reversing the tx and rx wires. Still no luck.
Has anyone actually used the acroname connector? Is there any reason that I NEED to have the 3.5mm jack? I simply plug the acroname converter into my serial port and then touch the wires to the pins. Is there something else that I need here?
Remember, I know my software, settings, and serial port are good because I read and programmed my pager through that port earlier today (with the actual motorola unit). But I can't get mine to work.
  #95 (permalink)
Old 04-21-2011, 2:59 PM
Nysff's Avatar
Send a message via AIM to Nysff
Cant this be done with just a plain ol USB Cable? just attached the correct wires to the correct pins?
  #96 (permalink)
Old 04-21-2011, 4:54 PM
Update:
I got my pager to program. I ended up using a usb to ttl cable from super droid robots.com. Here is the link to the cable I used:
USB to TTL 72in Serial Converter Cable
I cut the ttl adapter off the end leaving just standard wires
I just attached the green, yellow, and black wires to pins from a radio shack connector. Here is the connector:
25-Position Male Crimp D-Sub Connector - RadioShack.com
I tested multiple times until I got it to work. I used device manager to change my baud rate to 1200. I run windows 7 64 bit and windows automatically installed the drivers for the cable. I changed the usb delay in the program to 5 seconds and I still couldn't get it to work.
I then went back into device manager and clicked "advanced" and changed two things:
1. USB transfer size. I changed both to 1024
2. Lowered bm options to 10
PHOTO Attached of the advanced settings.
I then tried again and got it to work.
Once It worked I started to build it into an old charger stand. Because I was given a charger that was bad I didn't need to make it function as a charger and a programmer. Since I didn't need that option I removed the board from it. I then took a large channel lock and removed the plastic pin holders from the charger. (twist and pull). This is tough to explain, but I ended up making the holes flush with the rest of the pager (as viewed from the inside of it). I took my 3 wires with pins and placed them through the proper holes. I put my pager in (which then pushed the 3 pins back down a bit) and tested. It worked. Once I knew that my method worked, I took the pager back out, pushed the pins back in. Put the pager back in (pushing the pins slightly back out) and held everything in place. I then Hot glued the wires into place. I will attach a photo of the hot glued pins also. Once the first (minimal) layer of glue dried i tested one more time. Still worked so I then proceeded to fill the inside with hot glue so that no tension would be put on my wires.
There is only one minor issue that I have with my design. Because the pins are no longer spring loaded like the stock ones, I sometimes have to push the pager down slightly while reading it or writing to it. This could be solved my placing a dime on either side of the pins (underneath the pager) when you go to hot glue the pins. This would make the pager sit slightly higher and therefore make the pins go slightly higher up also.
I spend many hours of frustration on this project. Now that I have made it work I hope that my write up will help others! If you have questions please ask I will do my best to help.
Summary of my setup:
Usb to TTL cable
Charger that no longer functioned
Pins from a radio shack MALE d sub connector
hot glue!
Windows 7 64 bit
Hp laptop
NOTE: I am running this program "as an administrator". Don't know if it makes a difference or not. I DIDN"T make it run in compatibility mode though!
  #97 (permalink)
Old 04-21-2011, 4:56 PM
NO! It was explained to me like this.....Usb and rs232 (serial) send signals out at specific voltages. Those voltages are not the correct voltages needed to program a pager. A ttl signal is 3.8volts or something like that. A usb to ttl converter cable is needed to send the proper voltage
That is how it was explained to me!
  #98 (permalink)
Old 04-22-2011, 10:30 AM
Nysff's Avatar
Whoa. Good thing I didnt try. Lol. I woulda blew up my pager.
Thanks Bro.
  #99 (permalink)
Old 04-22-2011, 12:23 PM
I have never heard of any blowing up. It just wont work and you will waste a ton of time trying.
  #100 (permalink)
Old 04-22-2011, 5:39 PM
Nysff's Avatar
Just dont wanna fry it thats all. No One Local to me has these items so I guess I have to wait to order em
LinkBacks (?)
LinkBack to this Thread: http://forums.radioreference.com/motorola-forum/156798-programming-minitor-pager-cheap-diy-style-write-up.html
Posted By For Type Date
Advancing Ham Radio.. different ideas: Minitor IV in the Ham Band This thread Refback 01-21-2012 8:04 AM
