Old 10-05-2009, 02:53 PM
kb5udf's Avatar
Default Reliable Spectra Power Cables
Hi all,
I need a reccomendation for a reliable vendor of aftermarket power cables for 50w specta radios, with front mounted control heads. It seems like the stuff I've purchased in the past is woefully inadequate with regard to the gauge of the actual wire used (alot of insulation, only a little copper on the inside). This is causing radios to dim, reset, or have problems on tx (high power). I've observed the same problem with multiple cables, on multiple radios, hooked up to multiple power supplies, and shortening the cable as much as possible did help, but doesn't completely eliminate the problem.
P.S. I realize I can goto a radio shop and pay full price, but I can't quite afford that atm.
Alternatively, does anyone sell that odd connector on the back of the spectra? I could easily get the appropriate gauge wire and make my own harness.
Thx,
JB
Old 10-05-2009, 03:17 PM
I would also like any information on this, as i have a astro spectra digital radio, T99DX+130w so i assume i need a 130w cable.
Old 10-05-2009, 03:46 PM
Magnetsteve's Avatar
Sometimes you can find the OEM stuff on ebay for a decent deal
WAY to many radios....
Old 10-05-2009, 07:25 PM
n5ims's Avatar
This one indicates it's an actual Motorola HKN4137 for only $16. You probably can't get the parts to make it yourself for much less than that --> Radiodepot.com - Motorola Radios, Batteries, Accessories, Rentals, and Much More!
This one's $8 --> SB-HKN4137 Power Cable Assembly for GM300 Mobile
If you want to make your own, this shows how with part numbers of components --> Spectra Low/Medium Power DC Power and Ignition Cable
Old 10-05-2009, 10:00 PM
That "odd connector" is a standard automotive connector, and can be had at most any auto parts store in a variety of wire gauges. That's where I get mine.
12 volt radios are for wimps. Real radios can kill you.
Old 10-05-2009, 10:06 PM
No, that's not what that means.
Old 10-05-2009, 10:07 PM
Is the odd connector both of you are referring to look like this?
Old 10-05-2009, 10:12 PM
I apologize for my arrogance, I am a radio newb. What does it mean?
Old 10-05-2009, 11:11 PM
Yep. That's the one. The mate to that is available in auto parts stores.
Old 10-05-2009, 11:13 PM
No arrogance seen on your part, so no apology is necessary.
The best I can tell, the T99DX+130w is an Astro Spectra, 35 watts, with a W4 head. The +130W does not indicate that it's a 130 watt radio.
Old 10-05-2009, 11:28 PM
KF5DCI's Avatar
I think most people would know that the standard cable is a typical automotive harness available darn near anywhere, he may be talking about this connector.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=160366642099
BCD996XT, Pro-95, Pro-197, Minitor V, GM300 VHF, GM300 UHF, Yeasu VX-3R, ICOM ID-800H
Old 10-05-2009, 11:44 PM
He specifically mentioned a 50 watt radio, and the 50 watt class radio uses the automotive type connector.
Old 10-06-2009, 03:55 PM
Thanks for all the information.
One last thing, and i apologize if this is off topic, but the spec sheet i've found says it "Receives Rated Audo at 13.8v"
Would i be able to connect to my 12v car battery?
Old 10-07-2009, 12:28 PM
kb5udf's Avatar
Default Connector
Thanks for all the replies.
I wasn't aware that it was any kid of standard connector, having never seen it outside of the back of a radio. But then again, my do it yourself skills can be easily surpassed by most people who rode the
"short bus" to school. I think a trip to autozone is in order.
73,
JB
Old 10-07-2009, 01:48 PM
KF5DCI's Avatar
Your 12v electrical system in your car likely is closer to 13.8v then 12v. But to answer your question, yes.
Old 10-08-2009, 08:55 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Any examples since we're both in CA? Napa? I know Kragen and Autozone don't seem to have them. I used to use the ones at RadioShack in a pinch even though the wire gauge is too small.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 10-09-2009, 02:39 PM
I've been able to get them at Pep Boys. They come as a loop, with mating connectors plugged together. Cut it in half, and you have two connectors with a 6" pigtail, although one end winds up color coded wrong (black = positive). I've found them in #10 and about #14 wire sizes, in the section that sells trailer hitches and other towing items.
