Old 10-14-2009, 05:19 PM
Default XTS 2500 problem
The LCD screen on my XTS 2500 stopped working today. The screen does not display anything upon start up. Anyone have any suggestions? Or is this something I have to bring to a dealer?
Old 10-14-2009, 05:56 PM
Send a message via AIM to Josh Send a message via Yahoo to Josh
does it still work, tx/rx and function properly?
Was it on a trunking radio system?
If the answer to the first question is yes, then you may want to pop it open, carefully, and see if the display connector didn't come loose.
-Josh
Old 10-14-2009, 06:04 PM
Yes, it still functions properly. Transmits and receives fine. And, no it was not on a trunked system. The only problem is the screen not working...
Old 10-14-2009, 06:39 PM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
If you have sufficient skills and tools, you can replace the whole case and the display assembly at low cost by buying the parts directly from Motorola and doing the work yourself.
You can sign up for access to Motorola's parts and supplies ordering system (Called Motorola OnLine, or MOL) at http://businessonline.motorola.com
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 10-14-2009, 06:43 PM
Send a message via AIM to KS4VT
There was a factory notification a few months ago that advised that the flex inside can come loose if the radio is dropped or knocked around. You can pop the cover and check the connection first.
Old 10-19-2009, 05:37 PM
My friend ended up fixing the problem. By pressing down hard on the case he was able to get the screen working again. Probably a temporary fix, but it did the job.
Old 10-19-2009, 10:02 PM
Well known, very common problem with the XTS1500/2500.
It will happen again.
