I'll just add that when doing the scan list program on the radio, you can hit the "green" (blue) button a second time to make that channel the priority channel, if your radio is so equipped (to allow you to edit priority). I was pretty sure that red was a scanned channel, green was a priority scanned channel, and dark was non-scanned.
I make my department's HT1000s A = scan, B = scan off, C = scan program. Under fire gear it's easy to bump the switch off C onto either B or A, so I don't want a "normal" function on the C position.
I make the emergency button Volume Set Tone, the blue button Nuisance Delete, and the other two side buttons Squelch and Light (on display radios; otherwise I just assign it something that won't matter if it's hit).
--j.
VE6SRT
