Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 01-12-2010, 9:05 PM
KC9WWH's Avatar
Default Can't Get Minitor V into Programming Mode?
So, I'm not sure whats going on, but I've programmed a bunch of pagers, but for some reason this one pager will not go into programming mode or any other test mode for that reason?
Does anyone know of any way to force the pager into programming mode or a sort of hard reset?
Thanks,
Josh
Old 01-13-2010, 8:26 AM
Sounds like the reset button does not work? You could open up the pager to see if it just needs contact cleaner?
Old 01-13-2010, 8:28 AM
KC9WWH's Avatar
The reset button seems to work since when the pager is on I can hold it down and it will open up and it also resets fine after a page?
Old 01-14-2010, 10:32 PM
KC9WWH's Avatar
Well...I'm not sure what exactly is going on. I went ahead and opened it up and took a can of compressed air to it, put it back together and same thing. But, I did find out that with the housings off I could get it into programming mode???
After a few tries I was able to get it to stay in programming mode long enough to add the new call tones, so at least I got that done, but still not sure why its not working properly?
Anyway, thanks for the help.
Old 01-19-2010, 2:57 PM
Maybe the knob is a little off internally so it can't go into that mode easily
Old 05-25-2014, 11:32 AM
Did you ever figure out why it wasn't going into programing mode? I'm facing same thing and can't figure it out.
Old 05-26-2014, 1:54 PM
I had this problem a long time ago with a bad battery. It wasn't making the right contact and it kept turning off and back on.
Old 05-26-2014, 2:26 PM
I tried a different battery and no luck.
Old 05-26-2014, 6:16 PM
wizard of odd
Dirty programming contacts on the bottom of the pager? 90% of the time that's the problem when I get programming errors.
Old 05-26-2014, 6:33 PM
Pretty sure thats not it. When i put on "c" hold down the reset button and power it on... it wont give me the high pitch single tone indicating its going into prog mode. It also gives me squelch noise when i press the button to play the voice storage. I fear who ever had this pager in the past messed with the adv settings in the prog. Not sure where to start.
