Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 07-16-2010, 12:16 AM
Default [ASK] about controler 6809 and MTC3600
fist of all, I am a new member here and worked as a technician who handles radio motorola system.. i've some problems about controler 6809 and MTC3600
so, i wanted to ask about :
1. What a difference a controller 6809 and MTC3600 ?
2. Why the IR Quantar can't connect with mtc3600, meanwhile the existing 6809 controller connect to Quantar ?
i would be grateful if anyone would answer .. thx
Old 07-16-2010, 9:19 PM
MTC 3600 is a trunking controller that runs at 3600 baud rate.
IR Quantar is a IntelliRepeater and does not use a controller. This is the reason why the IR Quantar does not connect to the MTC 3600.
Old 07-18-2010, 10:00 PM
kuncunk's Avatar
how about controller 6809 ? could you give more explanation ?
in the quantar rss we have multiple choices such as intellirepeater, conventional, controller 6809 etc. And we choose IR quantar as 6809 smartnet so we have to provide controller MTC3600. Dou you have any idea about that ?
I have customer they have quantar non ir with controller 6809, can we remove controller 6809 and install controller mtc3600 ?
Old 07-19-2010, 10:23 PM
WayneH's Avatar
Forums Veteran
The MTC3600 is essentially an updated version of the 6809 controller. I can't recite any of the feature improvements but it's all new hardware. I don't think it improves on much other than just bringing all the components and interface up to date.
An IntelliRepeater can only be used as a network site in a SmartZone network (or setup "standalone" with NO controller with very basic features). So it's not even an option for the 6809 or MTC. I'm not sure what you're trying to do but there's nothing wrong with running a Quantar with a 6809.
If you PM me expect a long delay. Please use direct email for a quicker response.
Please follow the forum rules and contact a moderator directly, not via a thread.
Old 07-19-2010, 11:34 PM
kuncunk's Avatar
thank you very much for explanation.
But still i have a problem, if we want to replace controller 6809 with MTC3600 and connected to non ir quantar, can we do that ? or what should we do ? could you give suggestion please ?
Old 07-20-2010, 3:13 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 1.6; en-us; T-Mobile myTouch 3G Build/DMD64) AppleWebKit/528.5+ (KHTML, like Gecko) Version/3.1.2 Mobile Safari/525.20.1)
The answer to your question is, yes. But not if the station is set up for IR. As stated before, the MTC controller is an ugrade of the 6809.
Old 07-20-2010, 3:29 PM
Old 07-20-2010, 9:33 PM
thx a lot for the answer, maybe my friend kuncunk will ask the next question..
Old 07-21-2010, 1:41 PM
It's not too bad. Replaced a 6809 with a MTC3600. Motorola provided the jumpers for the DB-15? to RJ-45 and made a few new jumpers for the leased line modems for the CEB/console. Loaded the revised codeplug into the MTC3600 and away we went. The fun part was rebuilding the SAC!
-M142
Old 07-21-2010, 10:48 PM
kuncunk's Avatar
Thank you for suggestion.
Actually i have already done following task:
1. disconnected 10 base T ( bnc jumper between quantar )
2. connected db-15 ( quantar J14 ) to RJ-45 ( MTC3600 ) pin assignment
db-25 RJ-45
19 1
22 2
12 3
25 4
13 5
11 6
23 7
24 8
3. Reprogram quantar as smartnet ( 6809 controller ) and afew parameter of course
And the result is still not working, we can see from ACE board there is no communication between quantar and MTC3600. I just wondering because in the manual quantar is supported MTC3600. in my opinion there is some thing wrong with the jumper connection ( pin assignment ) between quantar and MTC3600, Do you have any idea ?
Old 07-23-2010, 10:37 PM
Do you have your ACE board set up correctly? What is the part number for your ACE board? What software version is in the ACE board?
Old 07-27-2010, 10:51 AM
kuncunk's Avatar
Hi, Luis
I am so sorry i can't answer your question because i was on site, not in the office. Actually i have already ask my friend to send part number and software version, but he didnt send it.
BR
kuncunk
Old 12-28-2010, 11:37 PM
Hi mas Kuncunk
You should replace the SCM board of your Quantar with CLN1293 so you can connect to MTC3600 SmartNet controller and you must adjust low data speed fsk modulation on your Quantar until in the right shape ( see Quantar manual )
Semoga berhasil
Old 12-29-2010, 8:53 PM
kuncunk's Avatar
Dear mbahmojer
Good idea . Thank u anyway
salam
kuncunk
Old 04-04-2013, 12:43 AM
Post MTC3600 controller
Hi mate,
Do you know much about MTC3600 controller? I need some information. I actually need to know if we can edit the controller configurations or not. Normally its a CDP file. Can we edit that file? Kindly assist. Thanks.
Regards
