MOTOTRBO CPS error #1646
radioman2001
New York North Carolina and all points in between
As listed in the title yesterday when I started up my MOTOTRBO program I get this error. Up to that time the software ran fine. Does anyone have a listings of the errors in this CPS? I can't look in the software for error codes since it won't run. I don't mind trying to repair my own problem I just would like to know where to start. Is it the software or a configuration problem in my computer.
davidgcet
did you do a windows update recently? i've had them crash various CPS before. try uninstalling and reinstalling the CPS, it does not wipe out your saved archives.
radioman2001
I found it, this is a corporate computer, so who knows what they do after hours. I was doing some cleaning and deleted a folder that had very little activity. Apparently MOTOTRBO uses Macrovision's licensing system to validate their software upon start up. I found the problem listed in the event viewer for errors. To correct it I copied the folder from another computer, but disabled the actual EXE file. Works ok now.
jamie398
radioman2001 - I have the same problem but don't fully understand how you solved it, are you able to explain in more detail please.
Batman_
it appears no one actually knows what error 1646 is, as no one has solved this.
cut and pasting from another folder of a working version is luck.
win7 64-bit.
I need to install this version, and that's ok.
People have installed it before and made it work, and doubtless this came up when 12 was new.
[-] Error
1646, commonlicenseinterface, Could not load file or assembly 'CLRCommonClientLicensingManager.dll' or one of its dependencies. The specified module could not be found.,
at commonLicensing........
Activation context generation failed for "C:\windows\WinSxS\x86_microsoft.vc80.mfc_1fc8b3b9 a1e18e3b_8.0.50727.6195_none_cbf5e994470a1a8f\MFC8 0.DLL". Dependent Assembly Microsoft.VC80.MFCLOC,processorArchitecture="x86".
Batman_
Sorry, I realize this was 2010 you wrote this, but which EXE are you refering to ?
