CM200 Software?
Muxlow
Super Secret
Middlesex County
Hey!
What type of CPS do i need to program a CM200?
I have R06.11.05 and Commercial Series R01.00
Neither of these work on the CM200's i have
Seem to work on every other radio CDM's HT's radius's mcs2000 (with the mts software, same with my astro xts and spectra)
Nothing seems to work with the cm200's thou.. does it take a different cps?
Or is the programming cable different then on a radius and cdm radio?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The software you need is RVN4191 which is for the CP150, CP200, CM200, CM300, PR400, and PM400 radios. I believe it is at least up to Revision N, CPS R5.09 now, but you will have to check with Motorola on that when you order it.
davidgcet
the proggramming cable is different, you need to jumper 2 pins to make the standard cable program a CM series. batlabs should have it, if not i have posted the details on this site a couple times in the last month or so.
