Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 01-27-2011, 10:31 AM
Default MDC Encode Problems
I have several HT1250's and never had this problem, programmed a HT750 the same way and noticed a problem. We use push button talkaround and when the HT750 goes to talkaround the radio does not tx the MDC code. yet the HT1250's all do. On the repeater both radios will tx the MDC. any thoughts
Old 01-27-2011, 4:23 PM
Check your programming...
Old 01-27-2011, 5:07 PM
i have gone over and over and over it and i am not seeing anything wrong with it
Old 01-27-2011, 9:19 PM
Wish I had a solution for you, but I am having the same issue with my EX600XLS...
Old 01-27-2011, 11:43 PM
RKG's Avatar
RKG RKG is offline
I'm not specifically familiar with the HT750, but traditionally MDC PTT-ID was intended to be transmitted only to a dispatch console, since until recently only dispatch consoles incorporated MDC decoders capable of decoding and displaying the PTT-ID. So it doesn't surprise me that a low-end radio would be firmware programmed to ignore PTT-ID when operating simplex.
Old 01-30-2011, 5:21 PM
I just dont understand why the HT-1250 and HT-1550 will do it on Talkaround but the HT-750 doent
Old 02-25-2011, 3:14 PM
SOUTH300's Avatar
Try programming a seperate channel as the talk around to that repeater, and make sure you set it to transmit the MDC ID on that channel. This will tell you if there is a problem with using the button as T/A as opposed to a seperate channel. Downfall is having to use a channel for a simplex to a repeater but it should work.
