Minitor V Programming
anehring43
NY
In engineering mode, can you successfully change the vhf lowband bandsplit from 37-40 to 45-47 cut? i tried it on a pager i recently picked up, it took the programming but its not recieving anything. whats going on here?
GTR8000
NY/NJ Database Guy
BEE00
No. Changing bandsplits is a hardware thing, not a software thing.
n3obl
Ø
PA
there are component differences in the different bandsplits.
Frank
Batwings21
Banned
You might get it to go 1 meg or so out of band with decreased performance, but there's no way that is going to work with those two splits. The only real thing the engineering mode is good for is adding a second channel.
You can't just change the software and have the pager switch bandsplits, there is also a hardware change involved, you need to obtain a receiver board capable of the 45-47 split and replace the board in the pager , once you've done that you can then make the software change.
