Minitor V VHF to UHF
WhiteKnight53
Hey guys
My fire dept has minitor 5s and we currently get dispatched on VHF. The county simulcasts so we are maybe thinking about switching to UHF because that is what all our fireground communications is. Is this possible or are we stuck with what we have. I have a programming cradle and the software.
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (BlackBerry8350i/4.6.1.294 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/126)
To change from Vhf to Uhf requires the reciever to be changed, this is not possible with software. A vhf reciever will not work on Uhf, nor vice versa.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
While your existing VHF Minitor V's can not be modified via software to UHF channels, you might consider purchasing UHF pagers as you can afford them. Since your county simulcasts VHF & UHF, you shouldn't loose any functionality for your members. Buy a few at a time as budget permits.
Your programming cradle and software will work for UHF just fine.
There will continue to be a strong market for used Minitor V's so you should be able to sell the VHF ones as they are replaced with UHF ones.
If you plan to do this, take a close look at how having some of your members on VHF and some on UHF would work. There may be some issues to consider that haven't been discussed here and can only be decided on your end.
