Motorola Minitor 5 software
matt131
QRT
Hello everyone,
I wanted to know if anyone can help me. My minitor 5 programming software is junk. can anyone email me new software?
Thank you very much
matt131
QRT
Anyone know the password for Engineering Mode?
I am told you can adjust the sensitivity of the pager in this mode.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
You really don't need Engineering Mode if you just want to use the Falsing Alert Adjustment feature which actually lowers tone decode sensitivity.
After you have Read the pager, close the User Data window if it is open. Hover your mouse over the picture of the pager and tap the "S" key.
If your copy of the PPS does not have an "Engineering Logon" choice in the Operation drop-down menu, there is no way to enter the password to get into Engineering Mode.
n3obl
Ø
PA
those instructions also works with the newest version of min4 software where motorola removed the engineer login dialog also.
Ver 1.72 has it.
Frank
jon47378
minitor engineer e
Does anyone know what the revisions are and if you change them how it effects the pager. My pager will not open up on tones, how can I make it more sensitive? Any help is appreciated, thanks
SteveC0625
Not sure what you mean by revisions. If you mean the version of the pager, that can't be changed unless it is a firmware revision, and those are few and far between.
Does the pager work OK when you are closer to the dispatch radio tower? If you're really close to the tower and the radio doesn't open, it's not a sensitivity issue. I'd more suspect incorrect tone or frequency programming. Or the pager is broke.
jon47378
In the minitor engineer logon info you can change the revision, ?of the software?, whatever that means. The frequency is correct, I decoded the tones several times, have programmed different variations of them but the pager hasnt opened up with any of the variations. The tones always go out twice, with 2 scanners on the frequency, sometimes one scanner picks up both sets and one scanner only one set. The pager may pick up the first or both sets, there is a lot of interference on all the radios, no matter where I am in town, there is always a buzzing. I have adjusted the squelch both ways and that doesnt make any difference either.
Not sure what you mean by revisions. If you mean the version of the pager, that can't be changed unless it is a filchmware revision, and those are few and far between.
