Old 04-23-2011, 4:48 PM
eyes00only's Avatar
Default Xpr 6350
Why can't I capture the frequency of this radio (Motorola XPR 6350) with my Pro83 or PSR500?
This is the first time I've held the freq. counting unit inches from any transmitting
unit and not getting any readout. WTH ?
JK
"There is a fine line between 'hobby' and 'mental illness'."
Old 04-23-2011, 7:06 PM
the radio is constantly transmitting and unkeying. this break in the signal is enough to mess up frequency counters and close call circuits. If you are close enough a close call will work but you almost have to be sitting on the antenna.
the best way to locate a TRBO signal is to search the freq band where you think the signal is. Using lockout in search will eliminate know or unwanted signals.
Old 04-23-2011, 8:50 PM
eyes00only's Avatar
Is the way the radio is supposed to work? I guess that's what they mean by digital. The antenna has VHF on it. I had the counter an inch from the antenna. I also tried your other method by searching 150.000 to 154.00 but will try that again. Thanks
for the reply sir.
JK
Old 04-23-2011, 9:51 PM
davidgcet's Avatar
if it is in digital mode then it is using TDMA and thus every few microseconds it unkeys to "share" the channel with another user. your scanner cannot decode TRBO anyway, but you can use a disc tap and run DSD to do it.
Old 01-22-2013, 11:22 AM
I hate to bring up an old thread, but just to clarify from what I have read, you CAN NOT scan (pro-106) a Motorola XPR 6350 if it is transmitting digital?
Old 01-22-2013, 12:11 PM
Git-R-Done's Avatar
Correct, you can decode MotoTRBO transmissions on a digital scanner unless you preform a discriminator tap and use a program that decodes MotoTRBO digital transmissions.
Callsign: N4CYA
MotoTRBO: Motorola XPR 5550
Scanner: Uniden BCD996XT
Old 01-22-2013, 2:16 PM
gtaman's Avatar
I found mine by using signal stalker. Just searched uhf and then I heard the digital noise. Un keyed and key up again to make sure it was the freq and it was.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
Old 01-22-2013, 9:33 PM
ramal121's Avatar
It depends on what you are trying to receive. If the TRBO radio is transmitting to a repeater, it will be pulsed on-off and a freq counter will not lock on to it. A scan type scheme maybe will catch it. Now if the radio is transmitting on simplex, it will be a constant RF transmission and anything should be able to sniff that out.
The fat one will never die! (http://www.kfat.com/)
Old 01-23-2013, 10:15 AM
Thanks for the responses.
So, using stalker I am able to find that the radio frequency the XPR 6350 is operating on. However, it is just digital static. Is there anyway to actually here the transmission?
Old 01-23-2013, 10:18 AM
Git-R-Done's Avatar
On your PSR-500 you'll have to or someone you know will have to do a discriminator tap inside your radio then download a program that you can find out the color code and talk group the people are using.
Callsign: N4CYA
Old 01-23-2013, 1:52 PM
gtaman's Avatar
You would need a discrimiter tap to actually "hear" the audio. But to find the freq you hear the digital noise that is just as annoying as p25 on an analog scanner.
Old 01-23-2013, 9:10 PM
Actually, that is not the case, with respect to simplex operation.
When a MOTOTRBO radio (or any DMR radio, for that matter) is transmitting in simplex mode, the transmitter is still being 'pulsed' on and off. In fact, the latest firmware for MOTOTRBO units allows them to sync between themselves in simplex mode, so that they can operate in a 6.25E mode (6.25 khz equivalent) without using a repeater.
John Rayfield, Jr. CETma
Old 01-24-2013, 10:33 PM
ramal121's Avatar
Yes, you are correct. My reply was clouded with visions of FDMA dancing before me.
Old 01-25-2013, 11:52 PM
LOL!!! That's good! :-)
John
Old 01-25-2013, 11:57 PM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
Default Xpr 6350
Part of that statement is not true. P25 phase 1 doesn't pulse on and off like trbo. P25 phase 1 is a constant carrier when the ptt is keyed.
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
Old 01-26-2013, 7:30 AM
MikeOxlong's Avatar
Default Xpr 6350
Where in this thread has anybody mentioned P25?
Mike.
Old 01-26-2013, 7:42 AM
KC2OBW's Avatar
Default Xpr 6350
Last time I checked P25 was considered DMR
WQOK964
Old 01-26-2013, 7:57 AM
MikeOxlong's Avatar
Default Xpr 6350
No, P25 has nothing to do with DMR.
DMR refers to radios built to a specific ETSI standard which P25 radios are not.
Mike.
Old 01-26-2013, 9:06 AM
KC2OBW's Avatar
Default Xpr 6350
I apologize for my miss information then. That I didn't know.
WQOK964
