Old 05-22-2011, 12:24 AM
Exclamation CDM750 issue....
ok i got my CDM 750 vhf 25w, and it just started to produce static, i cannot TX/RX, but radio does boot. i cannot hear wether its passing or failing self test, i would assume failing. it functions like it should, just no TX/RX, or system beeps, all static. i belive it could be the connecting ribbon running between the chassis, and the control head. btw, the radio is NOT setup for remote head. SOMEONE HELP!!!!!!
Old 05-22-2011, 10:51 AM
davidgcet's Avatar
verify you have a GOOD ground and good 12v. other than that if it is internal it is time for a radio shop.
Old 05-22-2011, 10:59 AM
i had tried it directly wired to the vehicle batt, 10a inline fuse aswell. im taking it to the shop tomorrow for the internal data ribbon. looks like im having them diag whats wrong with it. im praying this thing isnt fried. its slated to go into the new flatbed
Old 05-22-2011, 11:42 AM
could the data cable going from the radio to the control head be the issue? or is it a power issue, that caused an internal issue?
Old 05-22-2011, 1:57 PM
SD70MAC's Avatar
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2.2; en-us; Droid Build/FRG83G) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Sounds like an EEPROM CS ERROR to me.
SD70MAC OUT;
XTS5K VHF FPP,XTS3K VHF M1&M3,XTVA,XTS2500 M3 800,XTS2500 UHF Q FPP,HT1250 28-50, 3 CDM1550LS+ VHF 160ch,XPR4500 Q,CDM1250 42-54,GRE PSR-800,W3,W7,W9 Astro Spectra's
Old 05-22-2011, 2:12 PM
what would fix that? a reset to factory default?
Old 01-22-2013, 12:57 AM
well after letting the unit sit for a year. it will not even boot.. i think this unit is completely fcked.. any ideas on it would be nice
Old 01-22-2013, 9:38 AM
Skypilot007's Avatar
Newer CPS versions have default codeplugs. You could try to write one of those to the radio and see what happens. Since the 750 doesn't have a display I'm uncertain how the radio would represent the EEPROM CS ERROR. Perhaps a series of beeps or a tone. I've had some CDM1250's go EEPROM CS ERROR on me and the default codeplugs fix that issue every time. You will be starting from scratch for your programming but that's not a huge issue with the 4 channel 750. Good luck.
Old 01-22-2013, 12:38 PM
the issue is sky, that the radio will no longer even boot.. it does not turn on now..
