  #21 (permalink)
Old 06-25-2012, 12:04 AM
Originally Posted by 4-crime View Post
Anyone?
The radio has to be FPP anyways... so change it back to digital?
Sent from my Droid Bionic via Tapatalk 2
  #22 (permalink)
Old 09-05-2012, 8:38 PM
gtaman's Avatar
Originally Posted by 2009KVFD976 View Post
I got a similar sound on my HT1250 and PRO3150. DTMF tone with 000 and all the times and pretimes are set to the minimal setting. Its not an exact match but its close enough...
I do that with my cp200s but I do 9999 at 25ms which sounds grrreat!
  #23 (permalink)
Old 09-30-2012, 11:50 PM
DiGiTaLD's Avatar
Originally Posted by Gezelle007 View Post
If you are on a trunked network, and your radio is programmed to emit tones, if you have the Tones ON/OFF selection enabled in a Mot radio menu, does setting it to "OFF" disable the TPT as well?
Yes. Disabling the tones using the Tones On/Off selection also disables the talk permit tones when on a trunked system. It makes the radio completely silent except for whatever signals it receives coming out the speaker.
"...interoperability will always be a pain because the people who are supposed to be working together want nothing to do with each other until something really bad happens." -shell6
  #24 (permalink)
Old 09-30-2012, 11:51 PM
No it doesn't. Talk permit or busy tones will always be audible wether the tones setting is set to on or off.
  #25 (permalink)
Old 09-30-2012, 11:56 PM
Ive always heard the Talk permit tones using the DTMF method on the other radios. I didnt explore it too much maybe tried a few diff settings but just ended it there. Always heard it emit on the recieving radios. But was more of a test and to hear the tone
  #26 (permalink)
Old 11-24-2012, 9:27 AM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
Cop Sounds are real easy on Kenwoods. You can customize your own special alert tones (both the duration of each tone and the frequency) and set them to sound when you key up the radio. You can also do a PTT ID sidetone or proceed tone, which ever suits your fancy. If you set your volume high enough and your delay time long enough it'll even go through the mic too. Heck, you can even have the thing sing "La Cucaracha" to you when you key up. Maybe I should make a you tube video on how to do it.
I would be surprised if of those motorolas you couldn't enable pttID sidetone to make that same chirp or something similar to it. I know that icoms will do it.
  #27 (permalink)
Old 11-25-2012, 12:02 AM
I had to learn this the hard way.
Originally Posted by rapidcharger View Post
...You can customize your own special alert tones (both the duration of each tone and the frequency) and set them to sound when you key up the radio...
I knew you could make different tones for alerts and such, but how in the hell do you set them for TPT/PTT? I thought that was totally separate?
  #28 (permalink)
Old 11-26-2012, 9:04 AM
This is the motorola forum so I don't want to go off talking about kenwoods but if you have a kenwood I'm familiar with, I can try to show you in a PM.
  #29 (permalink)
Old 11-26-2012, 2:17 PM
gtaman's Avatar
It seems the sequence #### works the best for the dtmf hack.
  #30 (permalink)
Old 01-14-2013, 4:20 AM
Default Need help: Astro mobile error 12032 / unrecognized radio
I would like to ask some info regarding the error encountered on my subject, while downloading the codeplug on 100% suddenly prompted the error, i tried to power off and on all device still same problem. Im using dell laptop, 300 mhz CPU and DOS mode on ASTRO Programming software version 3.0.0.
**Your comment and suggestion is highly appriciated**
Thank you
  #31 (permalink)
Old 01-16-2013, 3:46 PM
Default DOS programming?
Thank you
If you're using a DOS RSS to program you should be booting from DOS 6.22 and bypassing your regular OS completely. The so-called DOS that operates under W95/98 and XP is not the equivalent of DOS 6.22. The so-called "imitation" DOS will often read the radio okay but usually fails when you attempt to write to the radio. In addition, a 300 mHz CPU is almost certainly too fast to run 6.22 correctly, so even if you boot directly into 6.22 it's likely you'll still have a problem. You can download DOS 6.22 for free from several sources on the internet.
  #32 (permalink)
Old 01-23-2013, 8:19 PM
Originally Posted by bezking View Post
Not at all. I appreciated the opportunity to learn something new myself. I hope you don't mind my adding your info to the OP.
It's damn funny that you posted this right after i watched the YT video, which didn't give ANY info except for what he was READING.
we need a WRITTEN, step by step, menu by menu, setting by setting directional posted here
  #33 (permalink)
Old 01-24-2013, 8:58 PM
4-crime's Avatar
Can TPT be done on an APX7000?
  #34 (permalink)
Old 01-25-2013, 11:07 AM
Default TPT tones...more info...
If you're legally on a trunked system a TPT can be part of your program. Otherwise, the only Motorola radio that will do a TPT today is a TRBO. The TPT on the TRBO means absolutely nothing but it IS a TPT tone.
  #35 (permalink)
Old 01-25-2013, 2:27 PM
gtaman's Avatar
I think he wants the hack like in the ht1000 and xts 5000 to do it in a conventuals freq. thier also the DTMF way.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
  #36 (permalink)
Old 01-25-2013, 2:48 PM
Yes, I thought of that, but all that hacked tone stuff is just that, and it doesn't sound like a TPT at all. Well, maybe in some vague way it does but we all know what it really is, and it ain't a TPT.
  #37 (permalink)
Old 01-25-2013, 3:20 PM
4-crime's Avatar
Well I have programmed it on a few XTS5000's in conventional mode and it sounds exactly like TPT. So I am not sure what you mean when you say it doesn't sound like TPT at all. And also, I am not looking to get on to an trunked network. I was inquiring how to do it on conventional channels on an APX7000.
  #38 (permalink)
Old 01-25-2013, 3:29 PM
gtaman's Avatar
I don't know if it can be done. I use on my cp200 the dtmf trick with #### and it sounds somewhat like one.
