Old 01-04-2012, 10:53 PM
Default HT1250..side pin replacement?
The accessory pins on the side of my radio are corroded and wore off...not allowing me to program it. Does anyone know the part number for just the pin area? Do I need a whole new board? Thanks!
Adam Kohnert
Old 01-04-2012, 10:54 PM
mancow's Avatar
You can usually get replacement housings on ebay fairly reasonably.
Old 01-04-2012, 11:02 PM
Do I need the whole housing? Or can I just get the copper piece?
Adam Kohnert
Old 01-04-2012, 11:49 PM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
What you need is a new flex ribbon, you don't need to recase the radio. what I would do is try and find a HT750 that is listed non working or for parts only and take the flex out of that.
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
Old 01-05-2012, 12:17 AM
OK....I would like a brand new ribbon if possible...Can I get a housing with it on there? Part numbers? THANKS!!!
Adam Kohnert
Old 01-06-2012, 9:58 AM
Devilz311's Avatar
Send a message via AIM to Devilz311
Is the board completely corroded through? I noticed with a few HT1250's at work that don't have the accessory port covers had a slight bit of corrosion on the contacts. I was able to gently scrape the oxidation off with a tiny screwdriver, and it worked fine.
Old 01-06-2012, 10:36 AM
Universal Connector Flex - Motorola p/n 8415169H01 list $ 16
You will also need a new escutcheon (black sticker) for the universal connector p/n 1386058A01, list $ 11 (24 pack)
You'll need the equipment & skills to unsolder the microphone and speaker from the old flex and to install them on the replacement flex.
Old 01-08-2012, 8:48 PM
WOW THANK YOU!!! I will let you know how it goes
Adam Kohnert
Old 01-09-2012, 12:11 AM
KC2OBW's Avatar
I'm surprised that the new flex's don't come with a mic or speaker.
WQOK964
Old 01-15-2012, 6:51 PM
Purchased the new parts........I will be putting them in tonight! Wish me luck......
Adam Kohnert
Old 01-15-2012, 7:50 PM
It worked!!!!!
Adam Kohnert
Old 01-18-2012, 7:21 PM
FIREPHIGHT's Avatar
Default ht 1250 parts
wiscomm .com
Tags
ht1250, parts, repair
