Astro CPS and XTS 3000 question
Bayamon, Puerto Rico
I'm using Astro 25 portable CPS version R16.01.00 to read an XTS 3000 model H09UCF9PW7BN and when it ends reading it I get an error "Open Radio Failed, Error Context: 24, Status: c000039e. Does this means this radio is not supported by this software or am I doing something wrong ? When I go to the radio service menu ( pressing side button II five times after self test) I get the following information, R 7.71.06, DSP 08.03.05 Flashcode 100004-000000-4, 1MEG. Any help solving or overcoming this issue will be greatly appreciated. Thanks in advance.
Jose
ASTRO2001
Cps wrong
You can't use ASTRO 25 CPS TO PROGRAM A XTS3000 that is a different CPS it is the ASTRO SABER & XTS3000 CPS. See Motorola did a dumb thing when they build the radio CPS software there is 3 different CPS software for the following radios XTS3500 Has there own CPS , XTS3000 has there own CPS and XTS5000, XTS4000, XTS2500, XTS1500
Thanks Astro2001, looks like I'm screwed because I believe I don't have that software in my arsenal or have a lower version of it. Correct me if I'm wrong but I think I won't be able to read the radio with an older version ?
N4DES
Retired 0598 Czar ÆS Ø
South FL
You also can't use an XTS5000/2500 cable (e.g. RKN4105A). You need the one for the XTS3000/MTS2000 that also requires a RIB box.
b7spectra
EMS Dispatcher
Cobb County, GA
The current Astro Saber & XTS3000 software is R05.03.00.
Just remember, the internet is your friend (This is the cue for all the SAPS to chime in).
ResQguy
Meh
The original Astro series of radios was almost 10 years old when the Astro25 line began. And here we are, now at the end of the line for the Astro25 in favor of the APX. None of these radios share any internals, so it makes sense that they would communicate differently. Also, the XTS3500 does not have CPS, only RSS.
MrAstroSaber
Walkie Talkie Man
New Mexico
The xts 3000 does have a cos out there you need. The cable will work fine. You can use a rib less cable to program just fine. How do I know this you ask? Well i have an xts 3000 and many other jedi radios and use the same ribless cable to program all of them. You need the astride saber xts3000 cos software and you will be fine. The internet is your friend!
FFPM571
Nashvillle
Go ahead.. find some pirated CPS on one of the russian sites.. When it corrupts your codeplug and bricks your radio.. I wont feel sorry for you. RIBless cables are good to brick your radio too..Have fun
MTS2000des
5B2_BEE00 Czar
exactly, just wait for the thread "my XTS3000 says FAIL 01/xx" after they download their bootleg stolen software, cheap knockoff RIBLESS cable...how to fix it? send to depot, B O A T..bust out another thousand...
Thanks for all the replies guys. Even though a couple of haters got into the conversation posting useless crap I got the information and answer I needed. Guess I'll have to dish the cash and go directly with the big M in this case. Have a good one.
FFPM571
Nashvillle
Im not a Hater..Im just a realist.. I know what happens when you use that stuff you find and try to use 2nd rate chineese crap
MrAstroSaber
Walkie Talkie Man
New Mexico
I have a ribless cable I have been using for years. Works great never had any problems. With that said the software that I use it with is the real stuff also. I use the cable on my XTS3000, MTS2000, Ht1000s, and my MTX8000s. I have also used it on my friends XTS5000. Never had any troubles even in the old school Moto RSS. Just because you did not know what you were doing ffpm571 and bricked your radio had nothing to do with the fact you were using a ribless cable. In fact if you look Moto them self have moved to ribless cables for the new stuff. So please take your untrue crap some place else. As for the software well your on your own there. Good luck to you
FFPM571
Nashvillle
I have never bricked a radio. I just fix them when others do. I have all original Motorola cables, software and RIB and newer Motorola RIBless cables. I speak from experence, not from a hobby level.
MrAstroSaber
Walkie Talkie Man
New Mexico
As do I. If people want to risk there radio with bad software thats there deal. But I have more then one non-moto ribless cable and have never had an issue
Skypilot007
Medford, NJ
Ribless cables are just fine for the XTS3000, been using them for years on many different radios and never had a failure. Also I think that russian site with all the software has been off line for quite some time. Like others mentioned the current Astro Saber & XTS3000 software is R05.03.00 and its out there in the wild, just search for it. You don't need to fork over a couple hundred bucks for something you can have for free.
Well I managed to have a Motorola Dealer program the radio for me and being it to be used by an all volunteer EMS group he didn't charge a penny for doing it. So I guess I got the good side of this situation.
N4KVE
PALM BEACH, FLORIDA
In my experience, some shops will give you a break if you use the radio for ham use, or VFD, as you are not using the radio to generate profit. It's nice these guys are still out there. GARY N4KVE
cmdrwill
So Cali
XTS5000 and R, radios. When reading get the error "Open Radio Failed, Error Context: 24, Status: c000039e.
Seems the radio is not there. I tried with the radio disconnected and same error.
Astro 25 Portable CPS R12.000
Also, I verified that the same computer, RIB, cable and RIB to radio cable worked with MTS CPS on MTS radios.
RIB to radio is a Motorola genuine Jedi cable with the test set plug.
Do I have the wrong cable????
