Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 05-05-2012, 4:37 PM
LMAAS146's Avatar
Default Radius M1225 Programming
I have a M1225 UHF I am trying to program... it is the 20 channel model. I have several channels that we use the "talk-around" function. I was trying to optimize the use of this radio and have just one freq and use the talk-around option button rather than having a RPT channel and a talk around channel. When I try to turn on the option button for the talk around, I get an error that says I don't have enough memory. Several of the channels are already simplex. Do I need to "count a channel" for each RPT'd channel that will be effected by this "Option" button?
Old 05-05-2012, 11:15 PM
Im having the same issue with mine.. Sorry i cant b of much help on this. I have all 24 channels pgmd and there are a few that r simplex and it wont let me use the button for repeater/talkaround. I got the same msg. Once again, sorry i cant b more helpful...
Old 05-06-2012, 1:10 AM
I believe that if you fill all of the channels on a M1225, especially when labeling the channels with alpha, there isn't enough room in the memory for the talkaround button to be used. Apparently the talkaround button uses a lot of the radio's memory.
Old 05-06-2012, 10:18 AM
I have been using 20 ch and Alpha labels on my VHF M1225 for years. Since all but three or four are repeaters, I use the T/A button, and it works just fine.
So, I think it must be something other than that.
I have the buttons configured as T/A, High/low, and DIM.
And I use scan.
Are you using any signalling ( like QC II ).
Since at least two people have run into the memory problem, I would be curious to know why so I don't ever run into that problem.
I think nearly all of my channels TX analog PL tones, and only a couple use RX PL tones.
Maybe filling all the PL tones or using DPL uses up more memory.
Old 05-06-2012, 8:33 PM
Copied off of batlabs:
Channel Expansion
There is a selection in the RSS to make the radio 24 channels. If you select this option, as long as you don't use the alphanumeric portion on every channel (or it will run out of memory) you can get 24 channels in.
However, we have been told that one of the greatest memory hogs is the Talk-Around button option. If you delete this option, you should be able to alpha-tag all the channels.
Old 05-06-2012, 10:39 PM
Like I said, I have all 20 channels with alpha names and talkaround.
So it must be something else.
Old 05-07-2012, 12:17 AM
He is talking about 24 channels. It is possible to squeeze in 24 channels if you DO NOT use the repeater/talkaround option. If you DO use the option button, you are limited to about 20 channels normally. Also, there is no dim option on a M1225, just a green/red color toggle.
Old 05-07-2012, 7:41 AM
SteveC0625's Avatar
Everyone is right, it is a memory thing. From what I can tell, it's easy to fill up the memory on a M1225 with programming and reprogramming.
Try this. Clear out the memory completely. Delete all the channels and the alpha tags. Start fresh. Add each channel as you want it but without alpha tags. Only use Rx PL when absolutely necessary. Only program other features if essential. You should be able to get your half duplex channels with talk-around programmed correctly.
With the channels all programmed, you should be able to go back and add alpha tags. Keep them as short and simple as you can because every character uses more memory, even spaces. For example, instead of Fire Channel 1, just program FIRE1 and so on.
Rochester-Monroe County 911 7010 1976 to 2003
Northampton Ambulance - Car 2829
KD2IAT --- WQPG808
Old 05-08-2012, 4:54 AM
LMAAS146's Avatar
Default Thank you
Thanks for all the input! I will give these ideas a try!
Old 09-16-2014, 9:56 PM
Default Programming Motorola M1225 UHF 20 Ch
I just purchased one off e-bay was curious as to how hard they are to program where can I get software any cables I need or can you program on the fly? any advice will be appreciated.
Old 09-17-2014, 6:51 AM
Fairly simple to program. . Software has to be purchased through (/\/\) which is expensive. Cables can be bought on eBay for around $20+. Or you can locate a Motorola dealer and have it pgmd to your specific frequencies. .. good luck on it!! I had the vhf and still have the uhf models. I also had the software for them but my laptop that ran winXP crashed and there went alot of my Pgm software and the new laptop has win 8.1 which will not run the 1225 or 1250 software that I have tried..
Old 09-17-2014, 7:46 AM
Location: New York North Carolina and all points in between
I don't believe Motorola supports that radio any longer. Software is listed on MOL as discontinued,and you will have to look for the software out in the wild, unless you know someone who has access to MOL. The rest (cables and RIB) is available on the net.
Old 09-17-2014, 8:00 AM
SteveC0625's Avatar
As already mentioned, the programming software is proprietary to /\/\, but NLA through their online sales outlet. It's kind of a quandry.
If you just have the one radio, and you are only going to have it programmed once or twice while it is yours, you may find it easier to just have a radio shop do the work. Typical programming costs for conventional analog units is about $30 to $50.
If there is a ham radio club near you, they may be able to help you for free or minimal charge.
If you do decide to acquire the software and cables, study the existing threads here and on the batboard about programming this radio and other /\/\ legacy radios. There's lots of good info for the reading, and you should learn some of the do's and don'ts of programming. Rule #1 is when you first read a radio: save a copy of the codeplug to your hard drive or a memory card. That way, if you make a mistake that you can not correct, it is usually possible to blow a known good codeplug back into the radio. Read, save, program to your heart's delight, save the new codeplug under a different file name (do not overwrite the original!) and then, and only then should you write back to the radio.
KD2IAT --- WQPG808
Old 09-22-2014, 10:04 PM
I'm wondering what to put in my M1225 its gonna be used for GMRS only can you default to talk around or should I Load all simplex and repeater pairs on seperate channels? can you program the radio for 5 watt output on the interstitial channels or just leave em out all together? any help here would be appreciated.
Old 09-23-2014, 12:58 PM
If you have a Moto account, the software is still listed for down load under resource center>software>two-way>discontinued products.
Both conventional and for the LS model
Also programming talk around buttons use's a lot of memory and not worth the effort.
If you have a repeater system and you need talk around, it is easier to just program a simplex channel.
