Professional Radio CPS issues
mattr11992
Hey all,
I been using Pro radio cps R06.12.05 to program my motorola HT-750 units that i have a whole ton of.
It worked on my windows 7 laptop pretty well for the first 100 or so, then after a month of not using the soft and RIB it wont read anything. Like nothings plugged into any of the comms.
I use a usb-serial adaptor with the rib and the appropriate cable for the 750
i even bought another RIB thinking that was bad.... im thinking it has to do with a software glitch?
any insite on this would be great.
WayneH
Forums Veteran
Super Moderator
Your master site
Please be aware that the Scanner Programming Software forum is for scanners, not two-way radios. We have a Motorola forum which is a better place to get help from. Please take another minute to familiarize yourself with all of our forums before creating a thread. Thanks.
Thread moved.
CommJunkie
FM19gt
A few things to check here. Keep in mind I use the same version of CPS on a Win 7 Ultimate machine.
Right click "Properties" on the icon for CPS. Go to "Compatability". Make sure you check the box for "Compatabile with Win XP SP3" and also check the box for "Run as administrator".
Once that's done, ensure the device manager didn't change the Com port number for your USB adaptor.
Then go to File > Read radio. It should ask you what Com port to use. If you just click the read radio button without going to File > Radio, it will use the last Com port selected, which if it has changed will not be correct.
Ensure the radio has a good charge on the battery. A low battery could cause it to read improperly. If your RIB has a battery, same thing with that.
If these don't work, I have a few more tricks that might help.
Make sure you have the right "Comm" port selected.
I've had situations where I've had to adjust the buffers for the port in the System settings. Could be that one of your other programs somehow messed it up.
The other thing I've seen is where a program gets installed that seems to grab that port on startup. Make sure you don't have any such programs running in startup that could be causing this.
I've also had an issue on an older Windows XP machine where a Kodak camera software program stopped one of the CPS programs from working. I had to uninstall the Kodak program to get it to work again.
Welcome to the wonderful world of Motorola software!
mattr11992
No change with setting privledges and making sure i have the right com.... new battery in the rib and charge on the 750
mattr11992
I am so confused all these parts should be working and the software is rather simple..... and ive done this before several hundred times.......
cabletech
Puget Sound
When dealing with radio programing and serviceing, some times it is easy to forget the simplest things.
Like, is the radio off when pluging any accy into it, (this includes headsets, spkr/mic's, programing cables)?
I say this because a lot of radios have a voltage on some of the circut and if the radio is on then you have a shop across the ins.
Make sure radio is off, and FURIMLY seat the cable, then power on, then see what happens.
