Old 11-25-2012, 10:58 PM
gonzalu's Avatar
Default XPR-6550 vs. XPR-7550
Can someone please help me decide between these two radios?
What are the differences and what are the pro's and cons? I would like to use on standard amateur UHF bands on simplex and repeater offset as well as get started with DMR nets.
Thanks for your input..
Manny
BC296D, BC125AT, BCD996XT, HomePatrol, AOR8000, PCR1000, PRO-2042, OS-535
Icom IC-U16, IC-H16, Motorola MotoTRBO XPR7550
First Scanner: Realistic PRO-24
Old 11-26-2012, 11:56 AM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
I think the biggest and most obvious differences is the 7 has a bigger display and full color, has more channels ( a lot more but probably way more than you'll ever need on the ham band) , higher capacity batteries, it meets more military specifications, the radio itself is bigger and looks more like a real radio in my opinion and it has some other features you probably wont ever use like enhanced privacy.
Old 11-26-2012, 1:13 PM
gonzalu's Avatar
Thank you... yes the screen of course was an obvious one :-) So I was really interested in the other points you made. From what I see on-line, I always thought the 6550 was larger and more rugged... go figure. I am surprised Motorola, with all it's 1,000,000,000,000 web pages does not have a decent comparison grid!! ugh...
The two radios seem to be similarly priced...
Manny
Old 11-26-2012, 3:41 PM
Avery93's Avatar
One thing to keep in mind about the new series TRBO radios (7550, 3500, etc.) is that they use a new proprietary antenna connector that isn't compatible with anything else, and the antenna selection for the new radios is so far quite limited.
Old 11-26-2012, 4:38 PM
This is a big problem in my case, & the reason I'll never own the 7550. If you will never need to connect a 7550 to an external mobile antenna, then get it. But the 6550 uses the common SMA connecter, & there is a common $1 adapter to connect the 6550 to a mobile antenna. I wonder if is possible to swap a 6550 antenna jack into the 7550 radio. Years ago the Icom 04AT used the bnc antenna, but the more desirable U-16 used a TNC connecter. It was a 10 minute job to install a bnc connecter into the U-16 there by having my cake & eating it too. So to the OP, the decision revolves around the antenna situation.
GARY N4KVE
Old 11-26-2012, 6:02 PM
gonzalu's Avatar
Yeah, thanks for clearing up the antenna situation. I heard about that but wasn't sure what it meant exactly...
Manny
Old 11-27-2012, 2:42 PM
It is NOT possible to switch jacks between a 7550 and a 6550. If you need an external antenna, buy a mobile.
List of obsolete radios.
List of degrees and certificates to impress people.
List of other information which is no one's business.
Old 11-27-2012, 3:16 PM
gonzalu's Avatar
I plan to use it as a Walkie Talkie with built in antenna, so it may not matter as much to me :-)
Motorola has alternative antenna models to chose from and I bet at some point someone may develop an adapter
Manny
Old 11-27-2012, 3:25 PM
I do have a 4550 mobile in my car. However my good friend just leased a Mercedes, & the leasing company will not allow him to drill any holes to install a mobile radio in the car. However, they will allow him to use a roof top magnetic antenna on the vehicle. So he needs to be able to connect his 7550 to the roof top antenna when he's far from the repeater. Had he known about the antenna situation, he would not have sold his 6550 to get the 7550. And his 5550 mobile sits in the garage because he can't install it in the new vehicle.
GARY N4KVE
Old 11-27-2012, 3:38 PM
gonzalu's Avatar
Does anyone have closeup pictures of the actual connector? I have searched high and low and can;t find one. I just asked our sales rep for our mobile radios here at work to see if he can get me a demo unit to play with :-)
Manny
Old 11-27-2012, 4:49 PM
Avery93's Avatar
A quick google search seems to show that Motorola does have a BNC adapter available for the new connector. It is the "SMA TO BNC ADAPTER-REWORKED" (part # 5880348B33), and is available from MOL for $40.
Old 11-27-2012, 7:32 PM
k3td's Avatar
Gary, I have leased several vehicles and always used NMO 3/4" hole mounts with mine. The leasing companies never said a word, they consider any dent, scratch or other damage - including a hole - smaller than a credit card to be 'normal wear and tear'.
Tad, K3TD
EM10dq
Old 11-27-2012, 7:48 PM
They actually did allow him to mount an antenna, but they were dead against drilling any holes in the interior to mount the mobile radio. Since he's usually in HT range of the repeater, & would rarely need an external antenna, he decided a mag mount would be good for the few times he'd need it. But I will forward the antenna adapter # to him. Actually, I won't as that's just a normal SMA/BNC adapter that is sold for $42. I get them for $1 at most hamfests.
GARY N4KVE
Old 11-27-2012, 7:55 PM
k3td's Avatar
Yeah, they have cables, sensors, etc hidden all over the interior of new vehicles. Too bad, I wonder if the local Motorola MSS or GE/Ericsson/Harris shop could help him out?
Tad, K3TD
EM10dq
Old 11-27-2012, 8:19 PM
The 7550 DOES NOT use an SMA connector. The THREADS are the same, and you can screw one in, if you prefer the outside shield of the SMA to be the radiating source.
The only Moto adapter I can find in a sales book for the 7550 is two pieces for service work, and its a few hundred bucks. I won't buy one.
Old 11-27-2012, 8:36 PM
A friend of mine has a 7550. As I recall, the antenna connector on the radio most closely resembles the old Saber single-pole antenna connector.. Not the same thing, obviously, but would remind you of the Saber setup.
But even on the old Sabers you could still get a two-pole external antenna connection on the radio via the connection plate on the back which was used by the 5487 SVA to run an external antenna, but I don't know if such an aux antenna connection is available on the 7550.
I guess Motorola just wanted the 7550 to have an antenna connection that would stand up to rough use, and the SMAs are noted, at least to some extent, to have a low MTBF.
Old 11-27-2012, 8:42 PM
I actually have a Saber antenna adapter that screws into the ant jack. It looks just like the SMA adapter, but it's solid metal, & there is no center pin. I got it years ago, & have never seen another one. I tried it in the 7550, but the threads were different. Bummer.
GARY N4KVE
Old 11-28-2012, 7:12 AM
gonzalu's Avatar
...and the stock antenna and one of the stubby optionals are dual use GPS / UHF jobs... what a mess :-(
Manny
Old 11-29-2012, 7:41 AM
rc50won's Avatar
The stock antenna covers 380-512mhz and is quite long. A better antenna is the 440-490mhz model which is just shy of 4" long and has better gain. This is the one I use.
There currently is no way to connect an external antenna to this radio. The RF port, located at top rear under a plastic cover, was designed for test purposes only and will not tolerate the stresses of an external cable. The /\/\ adapter for the RF test port cost around $300 and is made up of two parts.
I have owned both radios and their are pluses and minuses.
6550
+Better battery life - almost 2X
+Works with SMA-whatever adapter for external antenna
+Cheaper
-Will not be able to take advantage of the new functionality found in the 7000 model firmware with release 2.2
-Small display
7550
+Full size color display
+Works with the new functionality in upcoming 2.2 firmware
+Better ergonomics
+Better receiver performance
+One model covers both Low and High UHF bands
-Ships narrow banded only so you have to purchase CPS $265 and get the Entitlement ID for wide band
-No external antenna capability
-Lower battery life
Marshall
Marshall
Old 11-29-2012, 10:46 AM
gonzalu's Avatar
Thanks Marshall.
Question, will I be able to program my Ham 70cm repeater/offsets and also the DMR ham nets in digital mode at the same time and go between them?
Thank you.
Manny
Tags
6550, 7550, ham, motorola, xpr
