MDC PTT tones
dixie729
Daviess Co., KY
I've programmed 3 Motorola XTS3000 VHF radios with MDC signalling enabled with PTT ID on most of the channels we use.
Radio1: The tone is short when I key up on that channel. On another channel the tone is long when i key up. It is set to (leading and trailing).
Radio2: All the PTT tones are long on all the channels. (leading and trailing).
Radio3: The tone is short on one channel. On another channel the tone is long. (leading)
Conventional standard VHF system.
Why is this happening on some channels and not on others?
jtech48
OVB
The channels must be programmed under separate personalities and each personality has a specific mdc system assigned to it. Under the MDC system menu theres options for Leading PTT-ID, Trailing PTT-ID, PTT-ID Sidetone, and PTT-ID Short Sidetone
PTT-ID Short Sidetone is the single short beep you hear when you press the PTT button
PTT-ID Sidetone is the long beep you hear when you press it
The beeps are to remind you its sending the mdc id signal and for you to wait before talking
dixie729
Daviess Co., KY
Short side tone is not an option in the cps.
Leading PTT-ID - Enabled
PTT ID Sidetone - Enabled
Trailing PTT-ID - Enabled
Message
Radio Check
Radio Inhibit
That's all that's under the MDC System under the General tab
Kevin Absher - HTC Inspire 4G
