The channels must be programmed under separate personalities and each personality has a specific mdc system assigned to it. Under the MDC system menu theres options for Leading PTT-ID, Trailing PTT-ID, PTT-ID Sidetone, and PTT-ID Short Sidetone
PTT-ID Short Sidetone is the single short beep you hear when you press the PTT button
PTT-ID Sidetone is the long beep you hear when you press it
The beeps are to remind you its sending the mdc id signal and for you to wait before talking
In Flying, Carelessness And Overconfidence Are Usually Far More Dangerous Than Deliberately Accepted Risks
SoCal, Los Angeles Air Traffic
WQOE503
