Old 12-14-2012, 6:15 PM
Muxlow's Avatar
Send a message via Yahoo to Muxlow
Default XTS3000 Inhibit
Well this is strange
My XTS3000 has been working fine and dandy all day, just connected the programming cable to pop in some changes to the codeplug. Shut the radio off, connected the cable, turned the radio on and screen was blank and green LED light wont go off.
Tried to write the codeplug and says
The radio codeplug being written is set to INHIBITED!
This means that this radio has been shut down by dispatch
YOU SHOULD INVESTIGATE AS TO THE REASON!
You can only uninhibit the radio from the dispatch or with a Depot Tool
And i get about every error code possible flashing on the screen after that.
The radio was only set for P25 conventional channels and all RX so not sure how this happen...
Options? Fixes?
Muxlow
..Yeah iv got some radios
Old 12-14-2012, 6:33 PM
Muxlow's Avatar
Fail codes flashing on screen
FAIL 1F/90
FAIL 01/92
FAIL 03/90
FAIL 04/90
FAIL 05/90
FAIL 17/90
FAIL 1E/90
Muxlow
Old 12-14-2012, 7:08 PM
what band is it?
Old 12-14-2012, 11:20 PM
Muxlow's Avatar
800mhz
ASTRO25
Muxlow
Old 12-15-2012, 9:09 PM
gatekeep's Avatar
Send a message via Skype™ to gatekeep
Sound's like the controller failed. Any error code /90 is typically representative of a general hardware failure in a different area of the radio.
You could try writing the last known good codeplug to the radio, but without actually examining the radio, it's quite possible the hardware failed.
- Bryan, WQDK979
EFJohnson 5100 UHF-L III, XTS2500i UHF-H III, ASTRO Saber UHF-L III, MTS2000 UHF-L III, MT2000 UHF-H I, MT2000 VHF I, HT1250 UHF-L II, Baofeng UV-5RE
Old 12-15-2012, 9:20 PM
Muxlow's Avatar
As soon as i click WRITE TO RADIO i get that msg after a few seconds
The radio beeps as if its in programming mode then all the fail's happen
Tried to write 2 different plugs and nada. Radio was working about 2 hours prior to this
Muxlow
Old 12-15-2012, 10:31 PM
Send a message via AIM to jparks29 Send a message via MSN to jparks29 Send a message via Yahoo to jparks29
You do have an s-rec, right?
Old 12-15-2012, 10:39 PM
Huh??
Old 12-15-2012, 10:57 PM
Skypilot007's Avatar
MTSX-Lab and a saved s-record could possibly get it back. But if the controller failed it won't. In that case it needs service from a qualified technician with the proper tools and equipment for the job.
Old 12-16-2012, 2:11 AM
I'm thinking failed codeplug write, which could lead to similar symptoms.
The inhibit flag was what cued it, as I've seen that exact circumstance occur before.
Failed write, inhibit flag set, radio went bonkers, displaying garbage in service mode.
S-rec push fixed it.
Old 12-16-2012, 2:14 PM
Muxlow's Avatar
Even thou the radio was working for over 5 hours? Was programmed for about 2 days (put a different system then what is always in it) turned it on and off few times then on for the time i was in range of this other system
Shut it off for almost 2 hours turned it back on and it went dumb.
And a S-Rec. Errrmm... Now how would i go about saving that? Is it the file i use the tuner cps with?
If so then yeah.. the radio lets me read from it with tuner, just wont let me write a codeplug to the radio
Muxlow
Old 12-16-2012, 11:07 PM
Codeplug corruption can happen. But if it was working fine, THEN without notice, went retarded, then it's probably a hardware issue.
If you don't know what an S-rec is, you're dead in the water.
Go to p25.ca and post there, hopefully someone in your neck of the woods has the proper knowledge. Otherwise, you'd be shipping it somewhere.
If it's a hardware issue, you're toast.
If it's a corrupt codeplug, an S-rec push may help.
Old 12-17-2012, 9:35 AM
For the S-record, you would've had to had one saved already which it sounds like you don't. You need a program called MTSX-Lab to read/write these to a radio. You can use an s-record from another radio but it would need to be the same model number, flashcode, as close to your radio as possible.
Sounds like you had some trunking systems in there too. Are you sure you had it setup properly to passively scan. Perhaps you got inhibited by the system you were attempting to monitor.
Old 12-17-2012, 10:06 AM
This might be a dumb question, but if you read the radio, & save the file, is the "S" record in that file?
GARY N4KVE
Old 12-17-2012, 10:21 AM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
There was another member on here. A while ago he ran into the same issue with his astro saber not sure how he made out though.
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
Old 12-17-2012, 10:23 AM
KC2OBW's Avatar
Yes it is. But if the codeplug is corrupt and he never saved it before it went corrupt he's dead in the water if its not a hardware issue.
WQOK964
Old 12-17-2012, 10:32 AM
Thanks. I was actually just wondering for me should I have a problem down the road with any of my radios. I have saved Archives for all of them. You never know when the power might go off while programming a radio, although I use a UPS whenever programming.
GARY N4KVE
Old 12-17-2012, 11:07 AM
MikeOxlong's Avatar
No, the codeplug does not contain what you need to restore the radio. Lab has the ability to read s-records out of the radio and push them back in as long as the radio can still communicate.
If the OP's radio has a corrupted cp that the CPS will not recognize and will not let him dump a fresh cp in, then chances are lab will be able to dump an s-record in. He'll either have to use one he's saved or someone else's.
Mike.
Old 12-17-2012, 11:22 AM
Muxlow's Avatar
Do have the lab software. And finding a s-rec to match shouldnt be too hard. Rather basic flashcode in it
548008-000480-9 Model H09UCF9PW7BN
And the radio does have trunking, but only astro conventional RX only channels were in it. So no chance of it aff to a system or anything like that. And no system keys were uploaded to it.. So its just really wacky why all of a sudden after 5 hours of monitoring, then 2 hour time of no use and on power up.. does this
No possible way it can aff to anything when its all RX only and monitoring a trunked system via conventional astro channel
The radio will let me read/write with the tuner cps but not the other cps or read via lab
Guess trying to pop a s-rec in will be the sign if its hardware failure or what
Muxlow
Old 12-17-2012, 12:42 PM
gatekeep's Avatar
Remember if you load a donor s-rec into the radio that wasn't from the radio, that you retune it after dumping the donor s-rec. Since you say you can access the tuning data via tuner, I'd recommend jotting down the current tuning data.
- Bryan, WQDK979
