I think the MCS2000 is miles above the CDMs. They run cooler, they have better front ends, and MCS2000 CPS offers "drag and drop" compatibility with the MTS2000, making programming a breeze if you have multiple radios. True, you have to have one with the desired flashcode if you want all "whizbangery", but in reality, most people don't need MDC1200, Quick Call, or other tones for HAM use unless they are just trying to be whackers and make noise on ham repeaters to annoy others LOL.
The MCS also offered 250 mode options, close to a hundred more channels than a CDM1550, and IMO, the two line display on the model II/III is the best display on a mobile radio ever offered from that era, one 14 line for zone names, and one 14 line for channel names. Selectable PL is also a nice option, again, if the radio is flashed for these options- these come in handy for HAM use (lots of channels for repeaters, and user selectable PL/DPL tones, and big display for naming of channels and zones).
RSSI indicator? Seriously? The CDM/HT1250 RSSI indicator is about as useless as a Baofeng RSSI indicator. It's not like it's an accurate S meter on a TS-2000.
Out of band performance: on the 5 UHF "S" split MCS2000's I've programmed, all fell within spec for rated freq error, and TX power down to about 441MHz. The CPS modification is easy to do.
I see the MCS2000's en masse on everyone's favorite auction site, sure the radio is OOP, but it's also very affordable. People tend to want a kings' ransom for their CDM's, and if you want a high power (100 watt) MODERN (read not some 20 year old Spectra, Maratrac or Syntor X) mobile, there are few options other than an MCS2000, unless you go Kenwood, Vertex, etc.
I like them, I like the MTS2000 and other Jedi radios too, so I guess I'm a little partial. The CDM/Pro/Waris series just never said "quality" like the Jedi/Skywalker radios did.
