Old 01-28-2013, 6:51 PM
Smile What is Sticky Permanent Monitor Mode?
I have one Motorora TP-100 portable radio, What is Sticky Permanent Monitor Mode? Thank's...
Old 01-28-2013, 9:11 PM
WayneH's Avatar
Forums Manager
I've moved your post out of the Amateur Radio forum. Please use the Motorola forum for questions about their equipment. Thanks.
-Wayne
PM's are disabled. Please use email through my profile or: wayne_h at radioreference dot com
Please do not reply to my moderator activity. I do not follow those threads.
Old 01-28-2013, 10:09 PM
SteveC0625's Avatar
If you have the CPS for your radio, the definition is in the Help file.
I don't have that particular CPS, but here is the definition from the Pro Series Help file:
Sticky Permanent Monitor Mode occurs when holding the short-press Monitor Button for a Long Press duration. Once the long-press occurs, the radio remains in Monitor Mode until the Monitor Button is short pressed. Initiating Emergency Mode, Phone Mode, Scan Mode, or a Radio Call will also cancel Sticky Permanent Monitor mode.
This feature only applies for channels capable of Conventional Dispatch.
Old 01-28-2013, 11:54 PM
Thank's for your answer, I saw this document before. My trouble is "How to use Sticky Permanent Monitor Mode", and "What situation use this mode?" Thank's~
Old 01-29-2013, 8:16 AM
SteveC0625's Avatar
I don't find a lot of need for it, but since it disables PL, there might be situations where you're sharing the channel with multiple users with multiple PL's and don't want to step on anyone when you transmit. That might occur on a shared commercial repeater.
All of my usage is on public safety channels with one common PL for all or CSQ on the Rx side. Sticky Permanent Monitor isn't of much use for that. Others may have different points of view on this.
Old 01-29-2013, 6:29 PM
KG4INW's Avatar
It helps if you're listening to a weak signal that would be squelched otherwise.
How many radios can one man own? Don't ask stupid questions.
Old 01-29-2013, 9:42 PM
Thank's, I will test this functuon.
