Old 02-08-2013, 7:38 PM
Duplicate account of Tom Sherman
Default Motorola XTS3500R
I recently purchased a Motorola XTS3500R off ebay, and it needs to be programmed and recased.
Can i purchase a XTS3000 case and recase this radio into a 3000 series case? it is a model I XTS3500R
Also, is the CPS used to program the XTS/Astro Series the same to program the 3500R? i am looking for conventional programming only.
Old 02-08-2013, 8:01 PM
KG4INW's Avatar
Pretty sure the cases are interchangeable, but don't quote me on that.
As for the software, no, you'll have to get the 3500 RSS which runs in pure DOS only.
ETA: you won't have to worry about trunking since they were conventional only radios anyway.
How many radios can one man own? Don't ask stupid questions.
Old 02-08-2013, 8:03 PM
MikeOxlong's Avatar
No, you'll need XTS3500 RSS to program it.
Mike.
Old 02-08-2013, 8:05 PM
MikeOxlong's Avatar
Actually they did support trunking. I've got a VHF XTS3500 which has trunking. I don't know if it was officially Motorola supported but there are some out there with trunking.
Mike.
Old 02-08-2013, 8:08 PM
KG4INW's Avatar
Oh, OK. I was going by the sales brochure I had but I've never touched an XTS3500 before.
I am not even sure where i can find that type of programming? i am on ebay, but 3500R equipment is few and far between. Do they use the XTS series batteries?
Old 02-08-2013, 8:09 PM
KG4INW's Avatar
Yes, they use the same accessories.
Old 02-08-2013, 8:14 PM
MikeOxlong's Avatar
Yes.
The problem with the 3500's is the lack of support. They weren't a very common radio.
Basically what you've got for firmware and flash is what you're stuck with. I don't think I've ever seen a firmware upgrade for one.
Encryption boards are very rare. Unfortunately they use a board that's not used by any other model.
Mike.
Old 02-08-2013, 8:19 PM
I am only looking to program it for conventional use RX only, i got the radio radio off ebay for $19 and basically just using it for RX only, it is 470mhz-512mhz.
Now my problem is finding the programming for it. i am in not rush to get it programmed, but i would like to use it and have it programmed up. So if anyone knows how or where i can get it programmed, please let me know.
Old 02-08-2013, 8:47 PM
fire_master_21's Avatar
Trinity check your PM's
Motorola APX7000 VHF/UHF FPP
Motorola XTL5000 VHF P25
Kenwood Tk-5710H P25
Old 02-09-2013, 11:50 PM
Just had one more quick question,
I need a new volume knob for the 3500R, Can i purchase any knob set for the XTS Series radio? or does it have to be 3500R specific?
Old 02-10-2013, 12:54 AM
MTS2000des's Avatar
the knob itself or the knob cover? the knob cover just slips off, an XTS3K one should work just fine. I have a few, I'd be glad to send you one if needed.
All opinions, statements, posts, or information made public are those exclusively of the author, and not those of his employer, contractors or associates.
Old 02-10-2013, 9:07 AM
The XTS3500.. Is physically the same radio as an XTS3000 same everything,same case, same programming set up, and same accessories. The only difference is internal. It uses a different Software package that is for the 3500 only and DOS based, the encryption boards are 3500 specific
Old 02-10-2013, 9:17 AM
gtaman's Avatar
Wasn't the xts 3500r made specially for the FDNY. Or was it the XTS3000r ? I think it's the 3000r now.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
Old 02-10-2013, 11:32 AM
No .. the 3500's were an in between model, a few other agencies had them as they were availble in VHF and UHF but not 800. The Feds had some also.
Old 02-11-2013, 11:48 PM
This is how i received the radio, it looks like it just needs the knob covering, but i am not sure if i need the kit or just the knob?
I really would appreciate the knob if you have a spare one, not sure if you have an extra uhf stuff laying around for 470-512mhz?, But id throw you a few bucks
Old 02-13-2013, 12:01 AM
b7spectra's Avatar
EMS Dispatcher
A little ammonia and water along with a toothbrush will make it look as good as new!
\/\|k.e
EMS Dispatcher
http://icanhasdriverslicense.com
Old 02-13-2013, 10:23 AM
That was my next question to, I wasnt sure if i could use something like that to clean it, because i really didn't want to have to recase it, i am still looking for a knob and antenna if anyone has one or the other, i'd gladly pay for them!
Old 02-13-2013, 2:26 PM
KG4INW's Avatar
The XTS service manual states you can use one drop of dish detergent in one gallon of water with a toothbrush to carefully clean the housing. Obviously you won't need the whole gallon, that's just the ratio needed and you need to be careful not to get water where it shouldn't be.
Old 02-13-2013, 4:56 PM
Ive used Simple green and an old toothbrush and gotten cases that dirty clean. The drop of soap in a gallon is useless.
