Old 02-13-2013, 3:25 PM
Send a message via AIM to kb1ejw
Default Copying call lists between CDM types
Hello- First, let me say I'm still learning the finer points of Motorola CPS software.
I am in the midst of reprogramming channels, scan lists, zones, MDC call lists, etc to department radios. Essentially a whole new codeplug.
After making a lengthy MDC call list for a CDM1550, can I copy this to another radio's codeplug that uses the CPS software? i.e. EX600, Ht1250, CDM1250...If so, Could I also copy over zone lists, signalling lists?
Everything, for the most part, I want identical in all the radios that are programmed with CPS, and would like to have IDs to come across the radios capable of displaying them.
Thanks for any help
Why should I post what equipment I have.. . so you can come and steal it??
Old 02-13-2013, 8:17 PM
CommJunkie's Avatar
If there's a way to do it, I haven't figured it out yet. I've always done it manually.
Old 02-13-2013, 11:34 PM
mancow's Avatar
Drag and drop? I can't remember if Professional CPS supports that.
Old 02-14-2013, 9:15 AM
SteveC0625's Avatar
The Pro Series software doesn't allow any of this. Each code plug for each different model number has to be done individually. No drag and drop, no cut and paste.
Old 02-14-2013, 10:43 PM
ramal121's Avatar
And no fun!
The fat one will never die! (http://www.kfat.com/)
