Old 02-19-2013, 12:13 AM
CommJunkie's Avatar
Default MCS2000 cable
Looking at picking up an MCS2000. Is the programming cable the same pinout as the Waris series? Or do I need to spend the 20 bucks for a new one?
Old 02-19-2013, 3:37 AM
RodStrong's Avatar
I would recommend you buy this
Programming Rib Cable Motorola MCS2000 VHF UHF RKN4063A | eBay
Good luck.
Old 02-19-2013, 6:01 AM
KG4INW's Avatar
You can very easily/cheaply make one http://www.batlabs.com/images/mcs2000.gif
How many radios can one man own? Don't ask stupid questions.
Old 02-19-2013, 10:02 AM
Good luck.
I actually use this cable, & others from Kurt. They are well made, & reliable. However, I have 2 front mount MCS radios, & a 100 watt trunk mount. The cable works fine with the front mount radio, but for some strange reason, it won't work with the trunk mount radio. I had Kurt make me a special cable that programs through the acc jack instead of the mike jack. Works great. I believe the MCS uses it's own cable that doesn't work with other radios.
GARY N4KVE
Old 02-19-2013, 11:16 AM
MTS2000des's Avatar
What Gary said, the CDM/GM300 cable will NOT work with the MCS2000.
I use an old Polaris cable myself, can't say it will work with the trunk mount MCS radios, I've only ever owned/programmed dash mount versions.
FWIW, the Polaris cable appears to use the pinouts of the Batlabs schematic from what I can see underneath the hood on the DB-25 connector.
All opinions, statements, posts, or information made public are those exclusively of the author, and not those of his employer, contractors or associates.
Old 02-19-2013, 11:57 AM
uniden278's Avatar
Send a message via AIM to uniden278
The Kawamall radio-RIB cable on eBay is what I'm using right now and it works flawlessly for both front mount and remote mount programming. I also use their aftermarket RIB with about 200 programming cycles and no issues whatsoever. Prices are quite reasonable. I'd link you but I'm limited on my work computer.
Too many radios to list!
Old 02-19-2013, 12:43 PM
Wirelessly posted (Mozilla/5.0 (iPad; CPU OS 6_0_1 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A523 Safari/8536.25)
I recommend RFGuys out of Vancouver BC. Their prices are a bit higher, but their support is second to none. I will not buy another cable from any other source ever agin.
Interoperatablity is not a technology it is an attitude!!!
Old 02-19-2013, 1:09 PM
Skypilot007's Avatar
I've been using the Kawamall cable with a motorola RIB box for my dash mounts for many years with no issues. Also if you're using a ribless cable for your waris series radios you will need a RIB for the MCS radios. There are no ribless cables that I'm aware of for MCS2000 radios.
Old 02-19-2013, 6:14 PM
CommJunkie's Avatar
Thanks everyone for the help.
Old 02-19-2013, 6:39 PM
For what it is worth, the last couple of times I tryed rfguys, I did not get good service.
The first time took three weeks for cable to arrive and I am only a max three day mail service, and they do not answer your e-mails.
On the 5th of Feb I ordered a cable and now on the 19th it is still not here and after three email thru ebay and three more thu another address they still do not respond.
I will not use rfguys again, period...
I use kawamall, affordableradio, and empire_wireless for all my cables and they are all good responers.
Old 02-19-2013, 7:54 PM
CommJunkie's Avatar
Most of the cables I have came from kawamall. Never had any problems.
Old 02-20-2013, 4:41 AM
RodStrong's Avatar
That's interesting. I deal with mostly model II high watt remote mounts, but do mess with several 25 watt model I's and some dash mount model II's. I guess I have been lucky as I have never had that issue.
I also have used several Kawa cables over the years, and they have worked well. Wouldn't hesitate to buy them again, and likely will at some point. Overall though, head to head, I think the MRE cables are more durable and are of a better quality.
Now, if someone out there would come out with a ribless MCS2000 cable (hint, hint radio nerds), my life would be much more complete. I've been waiting for years.
Old 02-20-2013, 5:27 PM
cmdrwill's Avatar
The Spectra ribless cable is much the same, just need to change to the 25 pin connector.
Some RIB's do not work well with the MCS radios. Even the factory OEM Motorola ones.
MCS2000 RIB to 25 pin cable: http://batlabs.com/images/mcs2k25.gif
