Moto CDM1250 No Lights
W1CRN
Liberty, SC
I have a CDM1250 that has no back light, TX/RX, Monitor, or scan light. I have checked the ribbon cable the head was placed on another CDM1250 and it worked. I checked the CPS to make sure the lights where turned on but nothing. Any ideas?
firemansteve6921
Waterloo, NY
cdm1250
cdm series radios are known to have this issue. especially if the control head is remote mounted. you could try replacing the cables with new but quite honestly im willing to bet the electronics are shot in the control head. your best bet is to replace it.
W1CRN
Liberty, SC
I put the control head to a different radio and it worked fine. It is not a remote mount so I am hoping that its not in the radio itself
firemansteve6921
Waterloo, NY
hmm i wish i could help more. i havent run into that one yet. if you do find a fix let us all know thanks and good luck.
W1CRN
Liberty, SC
Does anyone have a picture of the R0410 P/N 066257B47 fuse on the PCB board? I can't seem to find it to save my life.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
[/IMG]
W1CRN
Liberty, SC
Thank you so much this will help me out alot. I don't know why I could not find it by looking at the detailed service manual.
W1CRN
Liberty, SC
That did the trick. Removed that fuse and put a piece of solder there and works like a charm. Thanks everyone.
Uh, just want to point out the obvious fact that something caused the fuse to blow in the first place. Did you find the cause? Replacing the fuse with the solder may put your radio at risk of a more serious failure if the same fault happens again.
W1CRN
Liberty, SC
Yes looked at everything. It happened when we were changing the unit from remote mount to dash mount and forgot to turn the.power to the unit off.
Fire125
FF/EMT/HMRT
SE Michigan
CDM 1550 lights not working at all
hey guys, so i couldnt figure this issue out yet. i have a cdm 1550 and all the lights are out; scan light, channel busy light, open monitor, and all the green background light! im using remote head and i tested it with another radio, it works perfect! all the lights and everything come up. but as soon as i hook it up to the other radio, none of the lights work! using the same flex and cables and... so i dont think its a flex issue! i appreciate it if anyone has any comment?
cmdrwill
So Cali
Bad R0410 jumper resistor used as a fuse, on top of the main PCB near the jack that connects to the control head (J0401).
