Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 03-14-2013, 3:28 PM
W1CRN's Avatar
Default Moto CDM1250 No Lights
I have a CDM1250 that has no back light, TX/RX, Monitor, or scan light. I have checked the ribbon cable the head was placed on another CDM1250 and it worked. I checked the CPS to make sure the lights where turned on but nothing. Any ideas?
BCT15/15X | BCD996T | BC785D | BCD996P2 | Pro-2055 | CDM1250 UHF | CDM1550 UHF/VHF | XPR 4550 UHF | XPR 6550 UHF | BC780XLT |
Ham = W1CRN | 1RWN CT52
Old 03-14-2013, 3:46 PM
firemansteve6921's Avatar
Default cdm1250
cdm series radios are known to have this issue. especially if the control head is remote mounted. you could try replacing the cables with new but quite honestly im willing to bet the electronics are shot in the control head. your best bet is to replace it.
Steven Henninger
firemansteve6921@yahoo.com
Seneca County NY feed.
Old 03-14-2013, 3:56 PM
W1CRN's Avatar
I put the control head to a different radio and it worked fine. It is not a remote mount so I am hoping that its not in the radio itself
Old 03-14-2013, 4:38 PM
hmm i wish i could help more. i havent run into that one yet. if you do find a fix let us all know thanks and good luck.
Steven Henninger
Old 03-14-2013, 6:36 PM
W1CRN's Avatar
Default This might be the probelm
Batboard • View topic - Backlight not working on CDM1250
if you think about it that would be it. I tired putting on a different head and that did the same thing. so that must be it
Old 03-14-2013, 9:44 PM
W1CRN's Avatar
Exclamation
Does anyone have a picture of the R0410 P/N 066257B47 fuse on the PCB board? I can't seem to find it to save my life.
Old 03-14-2013, 10:01 PM
SteveC0625's Avatar
[IMG][/IMG]
Old 03-14-2013, 10:03 PM
W1CRN's Avatar
Thank you so much this will help me out alot. I don't know why I could not find it by looking at the detailed service manual.
Old 03-14-2013, 10:06 PM
SteveC0625's Avatar
If you have the manual in PDF format, use the search function of Adobe Reader.
Old 03-18-2013, 11:46 AM
W1CRN's Avatar
That did the trick. Removed that fuse and put a piece of solder there and works like a charm. Thanks everyone.
Old 03-18-2013, 1:23 PM
mmckenna's Avatar
Uh, just want to point out the obvious fact that something caused the fuse to blow in the first place. Did you find the cause? Replacing the fuse with the solder may put your radio at risk of a more serious failure if the same fault happens again.
Old 03-18-2013, 3:21 PM
W1CRN's Avatar
Yes looked at everything. It happened when we were changing the unit from remote mount to dash mount and forgot to turn the.power to the unit off.
Old 03-18-2013, 11:07 PM
mmckenna's Avatar
That would have been my second guess. Glad to hear it's working for you.
I really like the CDM's I have, nice radios.
Old 08-19-2017, 10:52 AM
Exclamation CDM 1550 lights not working at all
hey guys, so i couldnt figure this issue out yet. i have a cdm 1550 and all the lights are out; scan light, channel busy light, open monitor, and all the green background light! im using remote head and i tested it with another radio, it works perfect! all the lights and everything come up. but as soon as i hook it up to the other radio, none of the lights work! using the same flex and cables and... so i dont think its a flex issue! i appreciate it if anyone has any comment?
Old 08-19-2017, 2:13 PM
cmdrwill's Avatar
Bad R0410 jumper resistor used as a fuse, on top of the main PCB near the jack that connects to the control head (J0401).
Old 08-25-2017, 4:21 PM
couldnt find it, would you please post a picture?
