I am wondering if anyone has any information on the jumper settings and wiring information for the Vega C-532 Tone Remote Console. I have been successful in making it a monitoring station, but do not have any of the requested information to make it transmit and control the desktrac.
I see by the subject that you have a Desktrac as the radio you are controlling. Are you sure that it has the Tone board in it?
One of the things strange about the Desktrac tone board, is the RJ45 connector. Pin 1 and 2 are used for the 2 wire tone remote - I always felt that was strange, why not use the middle two, or 1 and 8. So, your line out from the Vega would go to pin one and two.
I will guess that you already have this covered if you are getting audio out the RJ connector, it should then have the tone board and the proper pins - if you are connected to pin 1 and 2.
Have you programmed the desktrac? On the front there is a plastic cover over a small rotary switch. With a tuning tool or small screwdriver to position 1 for the radio itself, and 3 for the tone board (The screen in the desktrac RSS will tell you to turn postions a couple of time during programming)
Remember, you need two RSS programs, one for the radio, like the Maxtrac RSS, and one for the Desktrac.
