Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 06-26-2013, 12:12 PM
Default DTR650
DTR650 900mhz portables. Has anyone ever been able to identify what the actual frequencies these transmit on?
Old 06-26-2013, 12:23 PM
quarterwave's Avatar
902-928, Center is 915
It's an opinion. If you disagree, well, that's your opinion.
Old 06-26-2013, 4:06 PM
Thanks, I mean the specific frequency for each "channel" though.
Old 06-26-2013, 11:19 PM
I believe these frequency-scramble, so there is no way to monitor them and there isn't any real designated frequency for each channel. It hops around from frequency to frequency VERY rapidly when you transmit, and only other DTR radios can comprehend the patterns and receive the message as it is intended to be heard, it isn't like GMRS or FRS where there's the 462.xxx frequency and you can just plug it into a scanner or radio.
Old 06-27-2013, 5:51 AM
MTS2000des's Avatar
the DTR's use spread spectrum, there is no "channel" per se, center freq is 915MHz with 902 and 928 being the lower and upper limits as the other poster advised.
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
Tags
dtr650 dtr 900mhz
