Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Closed Thread
  #41 (permalink)
Old 11-05-2015, 5:54 PM
I will post a band plan tonight that should work
Sent from my SAMSUNG-SM-N910A using Tapatalk
  #42 (permalink)
Old 11-06-2015, 11:25 AM
N0WRE's Avatar
I got my XTS2500 to work on this but it misses a lot. Should it just be the CC and Alt CC to make sure it picks up traffic faster? I have two sites programmed in with all the relevant frequencies that showed up in unitrunker but maybe that's to much? Because right now I have each site programmed for the data, voice, CC and Alt CC that the program lists for the site.
Suggestions?
  #43 (permalink)
Old 11-06-2015, 11:30 AM
Send me your codeplug...
Ke5yoy@gmail.com
  #44 (permalink)
Old 11-06-2015, 11:46 AM
N0WRE's Avatar
Codeplug Sent. I am still working on the APX for this project. Thanks for the help.
  #45 (permalink)
Old 11-19-2015, 10:53 PM
4-crime's Avatar
Also, make sure that under Trunking System, Astro 25 that the box for "Validate NAC Against System ID" is UNCHECKED.
If the box is checked the channel will show activity but no audio will unmute from the radio.
  #46 (permalink)
Old 11-20-2015, 9:36 AM
N0WRE's Avatar
Actually I would say it depends on the system you are monitoring, I have mine checked and it works just fine. Radio scans and un-mutes with no problems.
  #47 (permalink)
Old 01-04-2017, 11:02 PM
Default Pahse 1 Cp
Guys can you shoot me a code-plug for a P25 Phase 1, Have a APX 7000 ide like to use to monitor local 800 IPSC system,
Thank's!
Stu
  #48 (permalink)
Old 01-05-2017, 8:45 AM
APX7000s can only do analog FM and digital P25 modulation. They cannot monitor or transmit in DMR/MOTOTRBO digital (e.g. IP Site Connect)... if that's what you meant by IPSC.
What do you need from the codeplug? Setup examples?
Semper Audire
I copy your 73s. Prepare to copy 9-Line, over.
  #49 (permalink)
Old 05-16-2018, 9:46 PM
I'm trying to do this with my APX8000 now; unfortunately, the P25.ca site no longer exists. Does anybody have a copy of their instruction sets? I'm stuck at a spot where every time I set the System ID, it flags it as invalid.
KC2ZHY | NRP / MICP | FF | Somerset County Emergency Services Feed
* BCD536HP * BCD436HP * BCD996P2 * BCD996XT * BCT15X * APX 8000XE * XPR 7550 VHF *
  #50 (permalink)
Old 05-16-2018, 9:54 PM
KevinC's Avatar
Moderator
Umm...you need a system key for each system.
This is pretty basic knowledge, so I'd suggest searching a lot more for instructions before you proceed any further.
And we'll be waiting for you to return asking why my radio won't turn on anymore.
Someone told me signatures are silly, so I got rid of mine.
  #51 (permalink)
Old 05-16-2018, 10:09 PM
I've tried this whole "searching for more instructions" thing; no dice. Figured I would come here asking for some more directed, experienced advice...
  #52 (permalink)
Old 05-17-2018, 12:19 AM
Here's my advice, stick with the scanners. Don't like that advice? Okay, learn what you are trying to do on a less expensive radio or get someone who knows what they are doing to do it.
Oh and the p25.ca instructions to NA scan are online. Try googling a little bit.
  #53 (permalink)
Old 05-17-2018, 4:22 AM
KevinC's Avatar
Moderator
Yep, and with that I'm closing this before it gets out of hand.
  #54 (permalink)
Old 05-17-2018, 6:21 AM
davidzimmerman's Avatar
i think the SAFE thing is to get one of the G4 Pagers i use to use a XTS2500 WORKS great
Closed Thread
