Old 12-12-2013, 3:01 PM
Default XTS portable - what type of antenna end fits?
If I wanted to use a mag mount occasionally in my vehicle with my xts3000 what type end would I need? Ex: RCA,n, rj, uhf, bnc, etc as example. What screws into the xts antenna mount?
Thanks.
Old 12-12-2013, 3:02 PM
SMA.
Old 12-12-2013, 3:14 PM
Default Re: XTS portable - what type of antenna end fits?
Female
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Old 12-12-2013, 8:56 PM
i'm hoping this will help point you in the right direction. i'm assuming that your mag mount is bnc.
BNC Adapters
first item at the top, item # SMF-BNF BK. i've used this to hook up my XTS1500 to my ST2 in the home, as well as mag mounts in the car.
Rob F.
KC2SQZ
Old 12-14-2013, 4:50 PM
cmdrwill's Avatar
The adapters cause more strain on the radios antenna jack. NOT recommended.
This is just one of the adapter cables available.
Amazon.com : RF coaxial cable SMA female to BNC male RG58 20 inches : Coaxial Video Cables : Electronics
Better to break an adapter cable than teh radio .....
Old 12-14-2013, 5:06 PM
I agree, I would buy a premium cable and adapter to minimize the loss. Alot of cables have 3-8db loss for a cable/adapter assemble that's relatively short at 1 few feet
Old 12-14-2013, 6:37 PM
rescue161's Avatar
KE4FHH
I repair the SMA mounts on XTS2500s DAILY. The SMA junction is attached directly to the PCB and they are very weak. Adding adapters to the XTS2500 is going to cause issues. XTS3000/5000 are a little better, but I would not recommend using any type of adapter on these or any radio for that matter.
Always use the correct connector (not adapter) and good quality feedline.
Hams Against Magnetic Mounts
