CPS question
spitcher1992
Cairo, Illinois
Does anyone know a specific list of radios that R6.12.05 will program? My department is looking at purchasing some new radios and don't want to buy new software.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The revision number isn't most important, but the part number is for identifying CPS. There's different CPS for each family of radios. HVN9025 is the part number for the Professional Series.
The latest version is R06.12.09. Keep that in mind if you buy used radios. You can not use your version to reprogram a radio that has already been programmed with a higher version. You may have to get the latest version from MOL.
Since your last posts have dealt exclusively with the Professional Series HT750's, CDM1250's, etc. you have mostly answered your own question.
CDM750,1250,1550, HT750,1250,1550, EX500 & 600. Includes the LS and LS+ versions of the 1550's. It will also do the MTX and ER series of radios.
BTW, you can find RSS/CPS lists via internet search. They are all over the place.
TSFIYF
spitcher1992
Cairo, Illinois
Quick question. I've never tried it, but can I program my CDM1250 via while it's actually installed in my vehicle? I normally remove it but it's becoming a hassle with all the upgrades and frequency mods we are doing.
firefive76
Kansas
As long as you can get to the mic jack.
spitcher1992
Cairo, Illinois
ok new one..
can i make an ht1250 display the persons name that its issued to? we are having issues with radios getting switched and "lost" and we want to keep track of who has what radio in a way that cant be tampered with. we have tried numbering them inside of the battery compartment, wrote serial numbers.. they were removed..
and last one. I PROMISE.
i have a friend that has a 1250, he can set an alarm on his radio. he actually uses it as his alarm clock. how do i do this?
sorry for the questions and thank you in advance
CommJunkie
FM19gt
ok new one..
Nope.
You could always engrave them.
spitcher1992
Cairo, Illinois
Dang. Aren't there some radios that do have that option? It seems like I've seen motos that do have a name just don't remember who had it or what the model was.
cg
Connecticut
Use the MDC1200 and assign an ID number to each radio. You can also program an alias list into every radio that will show the name of the person talking but every time you make a change, you would have to reprogram every radio. The numbers only would simply mean changing a master list and sending it out.
chris
spitcher1992
Cairo, Illinois
well i think i will just go with engraving. i just took a look at our old ht1000s from the police department and they were engraved under the battery.
spitcher1992
Cairo, Illinois
so, i just bought another cdm1250. the ebay seller advise me that he upgraded the codeplug and firmware versions. i programmed it up just fine. however, now my cps is telling me that my latest codeplug is 2.16 and my original is 11.0.... what does that mean?
