Old 01-23-2014, 6:51 PM
bwca44's Avatar
Default Speaker issues moto PMMN4039a
Hello all- recently I have had two moto PMMN4039A speaker misc that will transmit when connected to the ht1250/750 but will receive no audio. I have ruled out the radios as being the issue...both of these mics were very gently used, all pins are intact and extended
EMT
Old 01-25-2014, 2:41 PM
Default Get out the meter
If I'm not mistaken, that mike has an audio jack that you can plug a little earpiece into. Maybe rust, dirt, or cosmic dust has corroded or caused a bad connection on that. Get a 3.5mm jack and plug and unplug it a few times and see if it brings it back. If it does, cut the end off a Q-tip, soak the end in a little alcohol, (not Maker's Mark), and stick the cut end in there and try to clean it out. You could also just put alcohol on the end of the 3.5mm jack, but I do it the first way.
If that don't rectify it, identify which pin on the mike connector is the speaker, and ring it out, see what you get. Should be somewhere between 6 and 12 ohms. If it's shorted or open, get a new mike.
Old 01-26-2014, 3:35 PM
How old are they? What radios have you had them working on in the past?
These mikes have a small circuit board in them and are not repair able.
If I remember correctly, just because they have the same type connector as for the XPR series radio, they are wired a little differant for the basic ht750/1250 and will not fully funcation.
Old 02-02-2014, 7:29 PM
bwca44's Avatar
Default mic
The mic would work, then not work. Would test another mic on the radio and it woudl work fine. Would test the defunct mic on a 750 and nada. So I went ahead and ordered a brand new mic off epay.... and then the defunct mic started working again just fine! I give up. I'll hold on to the new mic incase the other one goes out again. Thanks gusy
EMT
