This may sound like a dumb question but is this CPS version compatible with Windows 8? I have the same CPS version and could not get it to work on Win7 64 bit. I believe it gave me similar error messages when I first tried it on 7/64 before I discovered it was not compatible.
Manny
R06.12.08 is almost the newest version. People are having mixed results with the Pro Series CPS and others on Win 8 machines. Same for Win 7/64. I think it it may be differences in the various manufacturers' PC's, but there's been nothing reported as a clear fix from other users, yet.
This version should run reliably on Win 7/32. It should also run very reliably on a Virtual XP machine under Win 7 (32 or 64).
If everyone would do some poking around here and on the batboard and on p25, you'll find that this is already a common discussion. There's a current thread on which os is best for this programming and it gives plenty of insight to the problem.
Motorola always seems to be behind the eightball on this whole thing. If you are a serious programmer, you're probably using an XP laptop
