Old 03-21-2014, 9:56 PM
Default Problem with CPS R06.12.08
When I attempt to read a radio the cps is telling me "Cannot get port names. Check if there are any ports on the computer." Anyone know what my issue is and how to fix it? Thanks in advance.
Old 03-21-2014, 11:02 PM
Skypilot007's Avatar
Looks like professional series CPS. What type of radio? What type of cable? Does the computer have a serial port or are you using a usb-serial converter. Operating system? Did you attempt to setup a comm port in CPS. Try all of the listed ports available? We need a little more information in order to help you out.
Old 03-21-2014, 11:16 PM
HT1250, Generic cable (had no issues with using with prior CPS) USB-Serial converter, Win 8 (Attempted on my Win ME machine and the install told me the software needed a newer version of Windows, As far as setting up a com port the initial attempt allowed me to choose between the 4 com ports but after the first attempt it only tells me the error message listed above using both the icon and the File/Read option so I can't even choose between the ports at this point.
Old 03-22-2014, 7:43 AM
N1SQB's Avatar
Cool
This may sound like a dumb question but is this CPS version compatible with Windows 8? I have the same CPS version and could not get it to work on Win7 64 bit. I believe it gave me similar error messages when I first tried it on 7/64 before I discovered it was not compatible.
Manny
N1SQB-AMATEUR EXTRA
The difference between men and boys, is the price they pay for toys!
Old 03-22-2014, 9:04 AM
SteveC0625's Avatar
Manny
R06.12.08 is almost the newest version. People are having mixed results with the Pro Series CPS and others on Win 8 machines. Same for Win 7/64. I think it it may be differences in the various manufacturers' PC's, but there's been nothing reported as a clear fix from other users, yet.
This version should run reliably on Win 7/32. It should also run very reliably on a Virtual XP machine under Win 7 (32 or 64).
If everyone would do some poking around here and on the batboard and on p25, you'll find that this is already a common discussion. There's a current thread on which os is best for this programming and it gives plenty of insight to the problem.
Motorola always seems to be behind the eightball on this whole thing. If you are a serious programmer, you're probably using an XP laptop
Please DO NOT email or PM me with general technical questions. They should be posted on the forum.
Let everyone have the chance to respond and to see each others' answers.
Old 03-22-2014, 9:06 AM
SteveC0625's Avatar
Study this thread which is in the Industry sub forum:
Best Version of Windows (XP,Vista,7,8) for Radio Programming
Old 03-22-2014, 1:13 PM
N1SQB's Avatar
Smile
Yup! You got it! Panasonic Toughbook CF-52 with a serial port running XP Pro SP3. How did you know? You been to my house? ...It doesn't go online so I don't worry about viruses, just radio programing software. It's the safest way for me! 3 CDM 1550LS+ and 2 HT 1550XLS portables. Not one single CPS issue yet!
Manny
N1SQB-AMATEUR EXTRA
Old 03-22-2014, 2:46 PM
Tried it on my Win ME machine and it wont even allow the install...says it requires a newer version on Windows...still no answer on why it wont load com ports on my Win 8 machine...
