Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 04-04-2014, 11:45 PM
Wink can i use an mt2000 / mts2000 speaker part on my computer?
is there an audio jack on it or something i want to be able to use it as a computer... meaning like i can talk through it as a computer microphone.
for an example (not using it for this of course), talking to people on skype. can the microphone part be able to transmit audio like that?
thanks
Old 04-05-2014, 10:48 AM
mmckenna's Avatar
Not without opening up and doing some major changes.
Old 04-06-2014, 9:33 PM
rjk_165's Avatar
I've thought about doing this too with some other microphones but as mmckenna said it probably requires dismantling and soldering and measuring and a lot of work.
Old 04-06-2014, 11:22 PM
mancow's Avatar
Search for the schematic, they are out there. They generally require around 8 volts. I'm sure it could be done with some modification.
Old 04-06-2014, 11:57 PM
Or you can go to Best Buy for $20......
Making your scanner useless, county by county.
Encryption, it pays my mortgage.
Old 04-12-2014, 1:08 AM
rjk_165's Avatar
Theoretically it could be done somehow, using a project box or something to enclose the connections, but it would take a lot of work.
I've thought of doing this with a normal palm mic the mobiles have, it eliminates the hassle of having to wire the audio-out into this.
Old 04-12-2014, 1:12 AM
Are we being punked or what?
Old 04-14-2014, 6:31 AM
productionguy85's Avatar
Smile
You say "speaker part", are you referring to a shoulder speaker mic or the actual speaker in a radio??? If you are referring to the shoulder mic, what model speaker mic do you have? If you have the higher end model, (don't know the model #) the cable that connected to the speaker mic it self, used a RJ45 connecter under the rubber boot, you can simply get a Cat5 cable and put a 1/8" plug on one end to plug it into your comp. likewise, if you want the coiled cable, simple cut off the radio connector and throw on an 1/8" connector.
If you don't like my HONEST opinion. Then don't read it. That is all.
BCD996XT
