CP185 Help
gordonfan954
Southwestern, NM
I was trying to program a CP185 using Entry Level CPS on Windows 7 and I kept getting an error that would say, "Unable to communicate with device. Please reset device and try again." I tried different com port settings, downloaded the Prolific drivers, changed the baud rates, uninstalling an reinstalling the drivers and CPS, to no avail. I am stuck. I don't know if its the radio, computer, or what. Any help would be appreciated. Thanks.
cabletech
Puget Sound
There is two versions of entry level CPS. One is for the CP185 ONLY (last ver v2.0) and the other is for the CT series of radios.
Neither will work in Win 7.
Both series of radio's were discontuniated several years ago right at the change over to Win 7 and no updates were issued.
Avery93
AL
Don't know where you got all of this info from.
The CP185 is still in production and supported by Motorola. The correct CPS is RVN5194 Entry Level CPS, latest version R02.02 according to MOL. The CP185 was introduced in late 2008, so considering older series CPS was updated for Windows 7 compatibility, I would assume the Entry Level CPS was as well.
gordonfan954, what cable are you using? If your using a cable designed for the CP200 series, I've read conflicting reports about whether or not they will work with the CP185. The CP185 has its own programming cable, P/N PMDN4077AR.
gordonfan954
Southwestern, NM
I'm using a cable that said it would work for the CP185 and CP200. I didn't know that they used different cables. By the way, I'm using Entry Level CPS Version 2.01 Build 56.
KG4INW
Midlothian, VA
Right, they don't use the same cable. The CP200 needs a RIB (even if it's built into the cable like many aftermarket ones are) and serial port while the CP185 cable is straight USB.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I use the CP200 cable and RIB routinely to read and program CP185s. It works fine.
I don't HAVE the dedicated CP185 programming cable.
BTW, I hate the CP185. It is an embarrassment to Motorola's name. I consider it to be their worst radios except for the BPR40 which is the very bottom of the barrel. When a 185 comes in, I hope I can condemn it. And I've had to condemn a few over such stupid little design flaws as being able to mash the PTT button far enough into the radio that you can rip the PTT switch off the PC board, sometimes including the traces.
KG4INW
Midlothian, VA
Hmm, not sure why it's not worked for me! I could try it sometime if I ever get some free time.
gordonfan954
Southwestern, NM
I'm gonna try a different cable and see if that works. What are the differences between the two cables?
Sent from my iPod touch using Tapatalk
