MSR2000 PA Agility
DisasterGuy
Maryland Shore
I am in possession of two MSR2000 stations that we removed from service after narrowbanding a couple of years ago. The intention is to convert these to amateur use to support a 2 meter and 440 repeater for ACS/RACES. I have found conflicting information on the frequency agility of the PA. Clearly the VHF continuous duty PA came in three splits (I have the 150 split) and I am unable to determine if the UHF PAs were multi-split.
Has anyone used a 150MHz split PA on 2 meters and validated the signal is clean? Are any modifications needed? Can anyone speak to the bandwidth of the UHF PA?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Can't recall what was done but we've been using a high power MSR formally on 154.8000MHz on 145.3700MHZ for 13 years now. Everything was properly checked out when it was installed.
I'd have to drive up to the site to check what split PA is on the unit.
