Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 08-06-2014, 5:48 PM
Default JT1000 noise
Hey guys. . I tried asking this on another forum, and while i received some good info, my question still remains unanswered. Ive got a UHF (R) JT1000 that when transmitting, makes a static noise. I own 2 of these identical radios, and have swapped out every part possible to figure out where the problem is, and have determined it is in the RF board. So my question is, is this something that can be repaired by someone with the proper tools/equipment, (obviously not motorola anymore) or is my radio pretty much done?
Here is an audio clip comparing my good radio to this radio with the problem
https://www.youtube.com/watch?v=Pdn2gF0hChM
Old 08-06-2014, 8:16 PM
MikeOxlong's Avatar
I would think it would be cheaper and faster to replace the rf board m
Mike.
Old 08-06-2014, 8:22 PM
gtaman's Avatar
A lot of the Jedi series had this issue. Moto issued a fix for them. I can't seem to find the report now but part of the board has to be unsoldered then re soldered . It's a grounding issue with the board. I have an MTS2000 that has this exact same issue.
My RT-1523E SINCGARS is just an oversized armored Motorola Maxtrac.
Old 08-06-2014, 8:36 PM
i was thinking about that... Would an RF board out of any jedi series radio with the same frequency range work, or is it more complicated then that?
Old 08-06-2014, 9:34 PM
gtaman's Avatar
Yes that will work. I believe all Jedi RF boards are the same.
Also tuning may be needed after the swap is done.
Old 08-06-2014, 11:18 PM
MTS2000des's Avatar
Or you can go into RSS on the donor radio, and write down all the softpot values, then transplant the board to the target radio, and enter all the softpot values.
Of course this ASSumes the donor radio was tuned and aligned and operating properly...
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
