APX 7000 "Invalid Codeplug"
mfn002
Bryan, Texas
I recently acquired a VHF/700 Model III APX 7000. When I tried to read it with the CPS, it gave me an "Invalid Codeplug" error. It'll read the model and flashcode configuration. I don't know if this has anything to do with it, but the flashcode is set to all zeros. Unfortunately, I don't have any codeplugs to load in to the radio. Is there a workaround for this, or is this a lost cause?
mikegilbert
MHz so good
Los Angeles
I hope this isn't one of those cheapo "for parts, or not working" ebay APX radios. If they're under $2500, they're most likely ALT/DEV radios.
When you go into service mode, what info shows up on the display?
mfn002
Bryan, Texas
Unfortunately, it's an eBay radio, I paid $1500 for it. It does transmit and receive fine, and has channels loaded into it.
How do I access the service mode?
mikegilbert
MHz so good
Los Angeles
1. Turn off the radio
2. Power the radio on
3. Press the lower side button (with two dots) at least 5 times.
4. "Service" will show up in the display.
You can hit the left arrow key to stop the display from cycling though the options. Then click the right arrow key to cycle through the info.
It should be along the lines of:
Host
DSP
Secure version
Model number
Serial number
Esn
Flashcode
Rf band
Tuning ver.
Processor ver.
mikegilbert
MHz so good
Los Angeles
You don't need to post the serial number or esn, as they're most likely 123ABC1234
mfn002
Bryan, Texas
Got it. Here's what I found:
HOST: F00.15.31
DSP: F00.15.31
SECURE: D01.00.24
MODEL: H97TGD9PW1AN
FLASHCODE: 000001-000000-9
TUNING VERSION: D01.05.00
PROC VERSION: 0MAP1710
There is both an ESN and SN (i.e., not 123ABC1234).
I find it strange that it actually has a flashcode, because the CPS read it as all zeros.
mikegilbert
MHz so good
Los Angeles
Looks like you've got a developmental radio on your hands. The "D" in the secure version indicates developmental secure revision.
I'd try to return the radio for a refund.
I've never come across an APX with such an old firmware revision.
KevinC
Junior Radio Guru
Super Moderator
Home
HOST: F00.15.31
DSP: F00.15.31
SECURE: D01.00.24
MODEL: H97TGD9PW1AN
You'll need "Development" CPS to read it. Thinking about it, the codeplug structure may have changed so much no current CPS (development or otherwise) may read it
Just curious, is the finish on the radio "shiny" or "crinkly"?
mfn002
Bryan, Texas
Unfortunately, I got the radio about a month ago, and just now managed to get the CPS installed and working.
From what I gather, are you saying this radio is unusable?
mfn002
Bryan, Texas
The finish on the radio is "crinkly".
XTS3000
The ONLY CPS version that will read and write that radio is version B00.02.00.46A
Unfortunally that CPS is special development version and not sold by Motorola.
Nasby
Ohio
Is there any way he can upgrade the firmware, etc with a flash to make the radio useable?
mfn002
Bryan, Texas
Can anyone tell me why Motorola did this?
It seems like kind of waste of a VERY expensive radio.
Anyway, I guess I'll keep it around as a parts unit. Maybe someday I'll come across a busted (non-developmental) one that needs a new case, display and keypad.
grem467
Houston, TX
That radio was never meant to get outside of Motorola. It was created when the radio was being developed and tested. Motorola engineers had all the tools they needed to test whatever your particular unit was created to test. I would not trust that radio to any sort of mission or operations critical usage. The problem is the fact that they are all over eBay fetching insane prices for extremely useless equipment.
Some of the early units even had xts5000 boards in them.
mfn002
Bryan, Texas
Then how did they get out on the open market?
grem467
Houston, TX
A lot of stuff leaks out of Motorola. Pallets of xts radios (panter88)... System key generator...depot etc.
Moto doesn't do a good job of getting them back (unless you post a service manual or codeplug, then the Gestapo comes out in force). But I digress.
jhal94
Pinellas County, Florida
Open it up and burn up the EPROM with a heat gun, then send it to depot :). Remove the tags and moto won't know a thing.
I'm kidding of course.
