Cdm1250 hum noise
nick223
Ottawa Illinois
I have a cdm 1250 in the back of an ambulance with a hum noise on tx of the radio. I hooked up a swr meter and it showed 5 watts reflecting back. I ran a new coax and antenna to the radio. With the new antenna and coax cable it's better but the hum is still present but not like it was. Anyone have any other ideas on what to do?
The ground was grounded to a ground block also tried grounding it to the chassis as well.
KC4YIN
Kinston NC
Are you able to switch it to low power and try it there. At first guess I would check ALL power connections for good clean contact. Not sure if that would help but it would be the next best and easiest / obvious thing to check. This would include the plug on the back of the radio. Unplug it and plug it back in making sure it has good solid contact.
Tech792
Central NJ
Do you have the hum with the ambulance engine running and turned off? Any chance you can post an audio clip of this hum? Try swapping with another radio if you have one.
KC4YIN
Kinston NC
Just to clarify, is the hum heard on the transmitted signal or heard through the speaker onthe transmiting radio?
nick223
Ottawa Illinois
The hum is on the receiving radios end. The hum is with the engine off and while running. I haven't switch radios yet. I'm looking for a recording but haven't found anything on my broadcastify feeds yet.
sfd119
Sounds like you've got noise from another electrical device. What else is turned on with your mobile?
