I recently purchased CPS, version R03. 11. 16, running on windows 7/8. I am trying to use it with a RIBless usb interface.
The program has loaded ok and can be read on the laptop. The usb cable has been tested and has been confirmed as running correctly, with the correct driver.
When I try to download the coreplug from the radio I get the following error message: "Couldn't open port. Check whether device/RIB are powered or not and the device to RIB, and the RIB to PC connection is ok".
I have previously had a similar problem usung older software on a machine runnig xp.
Help!
Help!
