HT1000 Banks
jrmull93
New York, NY
Just picked up 2 HT 1000's (1 UHF and 1 VHF) and i was just wondering about the 3 bank switch. Can I have 16 different frequencies in each bank ( total of 48) or are the 16 frequencies the same for each bank?
Just trying to decide how I want this programmed before I pay to ship it out.
Nasby
Ohio
16 channels is the limit for those radios.
The 3 way switch controls scan on/off, talk around, low power, etc.
cmdrwill
So Cali
The three way ' A B C' switch is programmable with HT1000 RSS.
I use the B position for PL Disable/monitor and C for talkaround/direct.
N4KVE
PALM BEACH, FLORIDA
MTS2000 top displays have 48 memories & work this way, not HT1000's. I don't understand why people still buy HT1000's because MTS2000's are just a few bucks more, & program with Windows run CPS.
jrmull93
New York, NY
Thanks for all the input I appreciate it. I think my next radio will definitely be an MTS
Last question regarding the ht1000, can the emergency button be programmed to work on select channels or does it have to be on for all if I choose to have it active?
krokus
Southeastern Michigan
In the radio I programmed for myself, I used the switch for banks. I had one for the base freqs, one for county FD freqs and one with the local 2m repeaters. Most of the radios used the switch for scanning and scan list selection.
Sent via Tapatalk
MTS2000des
5B2_BEE00 Czar
The HT1000 does not support banks, and it does not support more than 16 channels.
http://www.repeater-builder.com/motorola/jedi/pdfs/ht1000-specs.pdf
The HT1000/JT1000/Visar Page
It is possible to assign TALKAROUND to one of the A-B-C positions but not multiple zones.
I have programmed about 300 or so of these over the last 20 years and back in 1997 took an actual Motorola class on the Jedi series. To get more than 1 zone or bank operation, a customer would have to buy an MT2000.
The HT1000, JT1000 and Visar all share similar controller hardware, with the exception being the JT1000 which has modified firmware an CPU to accommodate a display and FPP of the 16 channels. The EEPROM available for codeplug storage is not enough to support anything other than 16 channels. End of story.
The codeplug structure is the same: 1 zone of 16 channels. If you look at the S-records from any of these radios, you will see there is NO WAY to enable zone operation. 640 bytes of codeplug space is all that is available.
If you have set yours up for zone operation, what version of HT1000/JT100/Visar RSS are you using, and how does one select the option for zone operation? Don't see that as one of the choices. How were you able to add more than 1 zone in the S-record? How did you get more than 1 zone to fit in the 640 byte codeplug and get the radio firmware to recognize it?
fdscan
New York
FYI, the HT1000 A/B/C switch functions are pretty strict compared to the MTS series.
Basically what I mean is that there is a set list of possible combinations for what you can use the switch for on the HT1000s, whereas on the MTS series you can set them to whatever your heart desires.
Figured I'd just chime in with that, it struck me by surprise when I almost bought one, I ended up buying the MTS.
