joespca
Does anyone know how to remove the password from ht1250 with this software?
Uh, do you mean the Pro Series CPS?Does anyone know how to remove the password from ht1250 with this software?
Did you check your PMs? I sent you a link that should answer your question.Yes I have the cps but need to know how to disable the password
I gave you the link to a long thread on the batboard. All the info you need is in that thread. If you search here on RR a bit, you'll find posts from me that contain the same info as well.I got a radio that was from a communication business they won't give me the pass unless I send it to them to pay. I know there is a way to disable the password in the cps but I can't seem to find it again online
Joe, I already gave you all the info needed in a thread over on the batboard.Does anyone else have any info
This is the most counterproductive way to do business I see.
Once a customer finds out that property THEY OWN, has been rendered useless, why anyone would do business again with that company defies explanation. This is tantamount to buying a car from Ford, but if you want to put new tires on it, you have to have Ford unlock the lug nuts each time - for a fee.
I've already given the OP two other links, one here on RR in this thread and one on the batboard in a PM, which contain the same information, but have more detail about hex editing the executable. I hope he's got enough to git 'er done.Your options are limited. Basically you need to read this:
Waris Professional Series Password Bypass
Then fire up your hex editor of choice and see if it works for your version. Seems it works on R06.12.08and older versions. Good luck and don't forget to share your results with the group.
Joe, you asked me the same question in a PM just a couple of days ago, and I gave you the same answer that com501 just gave you.Can anyone tell me the latest cps out for the ht1250ls
